if i buy an avermedia live portable gamer would i be able to capture and encode it in obs using NVENC? (i was told NVENC uses a dedicated chip on newer nvidia gpus) only reason i want to know is i wonna use the avermedia to capture my ps4 and pc and i was wandering if i could off loud the usage from my cpu to the dedicated chip on my 960 since they both encode in h.264
Why can't a Cleric/Priest/Bishop help a beginner KoC? Cause he's No-bless...When I post something, the thread dies.OR I'm incredibly good at giving informations,
OR I'm a thread killer.
Prolly both.
https://linustechtips.com/topic/437725-question-for-streamers-using-obs/
Can you stream already using... that?
yes however i cant capture and stream my ps4 with out skyrocketing my cpu usage wich is why i was asking if nvenc could be used while capturing other devices
Prolly both.
Why would you need it to if you are not using your pc but instead using your ps4 unless I am not understanding you correctly
Prolly both.
No, I meant can you already stream using NVENC.
I'm sure the PS4 already has live streaming to twitch as well as gameplay recording built-in. Why do you need it going through your PC?
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
He probably knows the limitations of streaming directly FROM the console?
I believe the streaming and video capture on the consoles are very limited
I see. In this case OP shouldn't really be worried about the CPU usage going up, as long as he's holding a solid framerate and as long as the computer isn't cooking itself (badly cooled).
Speedtests
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
Type            Server
OS              Ubuntu 14.04 LTS
RAM             2GB Non-ECC
Quotes of Fame
Streaming is absolute shit on consoles as opposed to running it through your pc.
PCPartPicker link: http://pcpartpicker.com/p/R6GTGX
Привет товарищ ))))
I believe that is indeed how it works, if you set the codec to NVENC it will use your GPU to encode what you're capturing.
thanks i figured it would only work when playing a pc game but ill try it and see if i can use nvenc while capturing a capture card
Prolly both.
