Thermal compound cleaning
Go to solution Solved by TheAmazingCookieFromSquare,
I use 97% so not sure on 91%
/jk
Anything above 70% is fine
As for @Darkman not so sure about you
Will 91% isopropyl alcohol be sufficient enough to clean the thermal compound off a processor?
Read the LTT Beginner's Guide; it's like a guide on how to not be a moron
 CPU: i5-4690k 4.1 GHz CPU Cooler: Cooler Master 212 EVO GPU: Asus Gtx 970 Strix MOBO: ASUS Z97-E RAM: Crucial Ballistix Sport 16GB (2 x 8GB) 1600 SSD: Samsung 840 Evo 500GB HDD: Seagate Barracuda 1TB PSU: Cooler Master 600W 80+ Bronze Case: Cooler Master Storm Scout 2 Advanced
https://linustechtips.com/topic/437717-thermal-compound-cleaning/
thats what i use. It works fine.
Join da discord
(Intel Core i5 4590 - XFX R9 280 - ASUS z97-A USB 3.1 - EVGA SuperNOVA 750B - 16GB EVGA DDR3-EDITION - NZXT H440 -
WD BLACK 1TB - OZC ARC 100 240gb)
#locked(ง ͠° ͟ل͜ ͡°)ง
I have to use 50%... You're fine.
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
/jk
Insert   Dank   Signature   Here.
91% is perfect for cleaning up thermal paste.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
/jk
It gets the job done... I've cleaned dozens of cpus and my 650ti along with my 480 with it.. Dried thermal paste is a real issue with 50% though... The 480 paste where it was glue was a pain cause of only 50%... But most of it was paper and I could grab it and tear it off. :P
Goo gone and then rubbing alcohol if its been there for a while. Goo gone works far better but it leaves an oily resedue. Thats when the alcohol helps.
Was it "hard" to rip "it" off?
( ͡o ͜ʖ ͡o)
Yah, considering that I use a dish towel, some water and my shirt? Definitely.
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
I use 70% so it's fine
The Brokish Boy v1: CPU: i7-8700k GPU: MSI Gaming X GTX ti MOBO: Asus ROG Maximus X Code Ram: G.Skill Trident Z 4x8gb 3200mhz DRIVES: 2x3TB WD Black , 500gb Samsung 850 EVO SSD, 500gb 970 EVO SSD Case: be quiet! Dark Base Pro 900 Black Headphone: ATH-MSR7 Mic: Blue Yeti Monitors: 27" BenQ GW2765 1440p; IPS, 27" Acer Predator XB271HU 1440p; VA
