Greasing Fan Bearings
Go to solution Solved by LogicalDrm,
Okay, just asking to see if you know something. I know oil is more common, just wondering WHY.
I think because it's already in liquid form and easier to apply. Squirt of oil, roll blades and you are done.
Hi,
Is it a good/bad idea to use machine grease on my PC fans?
- Why?
What is best to use?
- Why?
AMD Ryzen R9 5900X  | Arctic Liquid Freezer II 360  |  GIGABYTE X570S AERO G  |  2x32GB G'skill TridentZ 4000MHz  | MSI RX 6900 XT Gaming Z Trio 16GB Dark Base Pro 900 (Orange)  | TOSHIBA 4TB 3.5" Drive - Game Drive | KINGSTON SNVS1000G 1TB M.2 NVME SSD - Boot Drive | FSP Hydro PTM PRO 1000W |
Living Room PC: AMD Ryzen 2400G | MSI RX VEGA 56 8GB AERO | 2x8 GB Crucial Ballistix 2400MHz | Intenso 250GB SSD | Seagate 500 GB HDD | Node 202 + 850W PSU |
https://linustechtips.com/topic/437212-greasing-fan-bearings/
Why would you need to lubricate your fans ?
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/437212-greasing-fan-bearings/#findComment-5860831
"Greasing Fan Bearings" - giggidy  ^_^
CPU R7 3800X    Motherboard Asus Prime X370 Pro  RAM  24GB Corsair LPX 3000 (at 2933Mhz)    GPU EVGA GeForce RTX 3070 XC3 SC  Case Phanteks Enthoo Pro M
Storage 1 x 1TB m.2 (Windows), 1x 500GB SSD (Linux Mint), 1x 4TB SSD (for data Samsung 870) PSU Corsair RM1000  Cooling deepcool ak620(? probably)
Synology NAS 2 x 8TB
https://linustechtips.com/topic/437212-greasing-fan-bearings/#findComment-5860974
Because they make noise as stated below.
if they start producing noises you have to lube em. happens with old fans.
i did use machine grease  actually xD
Lol, how'd that Work for you? Didn't give a lot of effect for me, or maybe might've made it worse. Just clogged the damn hole with grease :lol:  :lol:
Not really a need for it unless they're super loud
They're pretty loud at 1600rpm
Try lithium grease
Okay? Will look into it, but I'm just really looking for something available and cheap, don't wanna Invest in grease or oil for a fan on my PC  :lol:  ONCE in a life-time thing haha.
Didn't know what else to call it lol :lol:  :lol:
You use oil for fans, not grease. Get something light oil like for sawing machine. And you put it into small hole in the middle of fan motor.
Why? :lol:
https://linustechtips.com/topic/437212-greasing-fan-bearings/#findComment-5861063
Why? :lol:
Now I'm not sure if you are joking with me. Where you planned to slab that creamy grease?
Seems like even bicycle oil should do the trick. Besides, you live in wealthy country. There's sure to be some cheapo oild available in local hardware store.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/437212-greasing-fan-bearings/#findComment-5861100
Hahaha! What I meant is, why the oil, why not just this grease?
Yes I either drilled a hole to the bearings (if they didn't have the rubber cap), or removed the rubber cap and added grease into the hole in the middle of the fans, where the bearings are.
Some fans (Cooler Master Sicleflow) don't have those rubber caps <_<  <_< <_<  <_<  So I had to drill those.
https://linustechtips.com/topic/437212-greasing-fan-bearings/#findComment-5861118
Your fan, your decision. Just saying that oil is more common with PC components than grease.
https://linustechtips.com/topic/437212-greasing-fan-bearings/#findComment-5861187
@Edgar R. Zakarian
well i dont give a crap about it, it works, and next time it will rattle, i will just clean it and do the same.
blower fan btw. if you have any oil for bike or something, id rather use that. grease is last resort and if you dont give a toss. and also, it doesnt leak.
oh and i used it for rifle bearing. for sleeve bearing use oil. actually for any other bearing better use oil xD
https://linustechtips.com/topic/437212-greasing-fan-bearings/#findComment-5861487
I saw a guy used Copper Grease in a Video.
He said it's good for that specific application.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/437212-greasing-fan-bearings/#findComment-5861515
@Edgar R. Zakarian
hahahaha okay, will consider that. The no leak part is a good thing about grease lol.
Just thinking people don't use it because it's more expensive, and built for harsher applications? (car)
Okay? Never heard of "Copper grease"
https://linustechtips.com/topic/437212-greasing-fan-bearings/#findComment-5861549
https://linustechtips.com/topic/437212-greasing-fan-bearings/#findComment-5861903
I use air tool oil.
My AMD Build:
FX 6300 @ 4.8GHz, Zalman CNPS14X, MSI 970 Gaming, 16gb 1866MHz AData Ram, 3D Club R9 280X, Corsair 600M Psu, Thermaltake V3 AMD Edition Case, D-link 1200AC WiFi, 240gb Mushkin SSD, 2tb WD HDD, 140gb WD HDD (recording gameplay), 5x CoolerMaster SickleFlow 120mm fans, Windows 10 64Bit
Sisters Intel Build:
I7 4790k @ 4.4GHz, CoolerMaster 212 Evo, Gigabyte Gaming 5, 16gb 1866MHz Corsair Ram, 3D Club R9 390, EVGA 650GS Psu, NZXT S340 Case, D-Link 1200AC WiFi Card, HyperX 240gb SSD, 2tb WD HDD, Windows 10 64 Bit
https://linustechtips.com/topic/437212-greasing-fan-bearings/#findComment-5863913
I'd use spray grease...
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/437212-greasing-fan-bearings/#findComment-5863939
