dem informations.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
It's my birthday on the 15th of this month I have a budget of 196 dollars or 127 pounds I made it down to micro atx: 350D mid: phantom 410, c70, cm storm scout full tower: cm storm trooper, haf x or a raven rv03 please help I have no idea what to get just need the best on airflow and cheapest if there's any cases that are better and either the same price or cheaper I'd love to hear them. Thanks
they are all good choices.
however, i would narrow it down to the 350d, phantom410 and C70. all good airflow and look beautiful. Just decide with the price/you like most.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
the thermaltake chaser mk1 has pretty good airflow and cable management options (fulltower)
last i checked it was around 120. and it's pretty quiet with the stock fans.
Right thanks ill have a look on scan at the cases with fans and all that jazz and see what I can do thanks FloRolf
no problem. you should check if your mobo fits in the 350d since its only matx, as you said.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
dont worry ive got matx mobo my current case is a haf 922 so it isnt hard to misstake it for a normal atx
so, why do you want to get a new case? the 922 is very good. o.O
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
I want to keep the 922 but the problem is the dust filters have all become broke all the thread in th have come undone and my 6870 blower fan is like a hair dryer because of the amount of dust that comes in my room is really bad dust basically I have 215 pounds too spend and I need a new headset so 90 pounds is going on the headset and the rest for the case fans, led light kit that sort of thing that why I'm so stuck for what case to buy and that's why I'm not keeping the 922 sorry for the ramble
but why dont you just get a few new fan filters for 20bucks and you are good?
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
That's a good one Ermm would you recommend any black spray paint so I can do the inside ahahaahaa
sorry, i dont know much about painting ^^ but i guess there are a lot of options for colouring metal! ;)
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Well I dunno wat you said though I'm gonna have a look into dust filters some paint if not ill just get a c70 just a shame I don't have enough money for everything or I'd buy a 900d for the hell of it but thank you for the help, you got steam/teamspeak?
fracal r4
Intel 4770k   -   Corsair Vengeance Pro CL9 16gb 1866mhz   -   Corsair Air 540   -   Gentle Typhoon AP45   -   Corsair ax1200i   -   Razer Death Adder 2013   -   Filco Majestouch 2   -   Crucial m4 256gb ssd   -   1TB Western Digital Black   -   Asus Maximus vi Formula   -   Bitspower matte black fittings   -   Black Ice sr1 240mm and 360mm Radiators   -   Swiftech mcp655   -   EK x-res pump top   -   Promochill Advanced lrt 3/8 5/8 bloodshed red tubing   -   swiftech apogee hd cpu block   -   Asus pb278q 1440p monitor   -   Razer Carcharas Headphones   -   Razer Vespula Hard Mouse Pad   -   Arctic Silver 5 TIM   -   Sapphire r9-290x   -   Ek-fc R9-290x Waterblock and Backplate
Usually you'll be able to find informations on the can you intend to buy.
Best way to color metal is to use some sandpaper to roughen the surface, clean with alcohol and once it's COMPLETELY dried out, use a grounding spray, have it dry about 24h to be sure all of the solvent has evaporated and then paint it in any color you want. If you want to increase scratch resistance, add a layer of clear polish.
@ Case:
Fractal Design Define R4
Frost upon these cigarettes.... lipstick on the window pane...
If you have a matx, please consider getting the 350D instead.
A matx mobo in a mid tower is just awkward.
