I'm looking for a case with good airflow and support for a radiator mounted at the top.
CPU: Intel Core i7 4790K
CPU Cooler: Noctua NH-D15
RAM: Corsair Vengeance Pro 16GB 1866MHz
GPU: Asus Strix RTX 2060 OC
Motherboard: Asus Maximus VII Hero
Storage: 1TB, 500GB, 250GB SSD's, 1TB SSHD
Case: Corsair Carbide Air 540
https://linustechtips.com/topic/436741-a-case-with-good-airflow/
define s
take a look, a great case at $70
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/436741-a-case-with-good-airflow/#findComment-5854450
Noctis 450
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/436741-a-case-with-good-airflow/#findComment-5854457
Define S
Define R5
Noctis 450
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/436741-a-case-with-good-airflow/#findComment-5854472
budget?
Define S
Enthoo Pro
Enthoo Luxe
Evolv ATX
https://linustechtips.com/topic/436741-a-case-with-good-airflow/#findComment-5854477
What is your budget for a case? The recomendations will vary based on what your willing to spend.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/436741-a-case-with-good-airflow/#findComment-5854491
Budget is max 280$.
https://linustechtips.com/topic/436741-a-case-with-good-airflow/#findComment-5854502
Budget is max 280$.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
Can you link us to where you're shopping?
What are you planning to put inside?
https://linustechtips.com/topic/436741-a-case-with-good-airflow/#findComment-5857275
oh yeah sorry i forgot that. I'm just planing to move my current build over into another case since i don't like the H440. The page im shopping from is in danish but i'll link it anyway https://www.komplett.dk/category/10149
https://linustechtips.com/topic/436741-a-case-with-good-airflow/#findComment-5860553
Air 540...it's in the name :D
CPU: Ryzen 2700x Cooler: NZXT x52 Kraken Motherboard: ASUS Crosshair Vii RAM: Team Darkgroup 3600 16GB DDR4 GPU: Palit GTX 1080 Gamerock SSD: Samsung 840 EVO 256 GB, 500gb 870 Evo, 250gb 970 Evo m.2 HDD: 2TB Seagate Barracude Case: Meshify C PSU: Corsair AX860i OS: Windows 10 Pro
Laptop: MSI GS70 2QE
https://linustechtips.com/topic/436741-a-case-with-good-airflow/#findComment-5860599
Thank you! Might go with this one :)
https://linustechtips.com/topic/436741-a-case-with-good-airflow/#findComment-5860723
I've got one. It has good airflow, but the dust filter on it sucks.
in the front or because of the missing PSU filter?
https://linustechtips.com/topic/436741-a-case-with-good-airflow/#findComment-5881166
Both. The front one just doesn't catch as much dust as I would like.
Dubs are better than subs
https://linustechtips.com/topic/436741-a-case-with-good-airflow/#findComment-5881182
Hmm. Well i already ordered it and if it really is that bad i'll just buy some new dust filters
https://linustechtips.com/topic/436741-a-case-with-good-airflow/#findComment-5881245
That's what I would suggest. It is a good case, just has dust problems because I smoke around it I guess.
https://linustechtips.com/topic/436741-a-case-with-good-airflow/#findComment-5881261
