Hey guys, this is my first build that I will be using mostly for CSGO, and just other games that don't require much.
This is the build that I was recommended: http://pcpartpicker.com/p/xWxDHx
Nothing to special, but it's what I could get because of my budget restrictions. (around $750)
So tell me what you think, feedback is appreciated!
https://linustechtips.com/topic/436256-first-build-opinions-needed/
For $750 and all peripherals I think I can make you a little something more powerful. Gimme a minute or two.
Much better. Here you go:
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor  ($111.99 @ B&H)
Motherboard: Gigabyte GA-H81M-S1 Micro ATX LGA1150 Motherboard  ($37.99 @ SuperBiiz)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory  ($39.49 @ Newegg)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive  ($43.00 @ Amazon)
Video Card: PowerColor Radeon R9 285 2GB TurboDuo Video Card  ($158.98 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($32.99 @ Micro Center)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($49.99 @ Newegg)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($15.00)
Wireless Network Adapter: Rosewill RNX-N250PCe 802.11b/g/n PCI-Express x1 Wi-Fi Adapter  ($15.99 @ Newegg)
Monitor: LG 23MP57HQ-P 60Hz 23.0" Monitor  ($119.99 @ Amazon)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($26.98 @ Newegg)
Headphones: Logitech G230 Headset  ($39.99 @ Newegg)
Total: $692.38
Generated by PCPartPicker 2015-08-23 19:12 EDT-0400
You can get a copy of WIndows for like $15 on https://www.reddit.com/r/microsoftsoftwareswap/ and then upgrade to Windows 10 for free. 285 will destroy the 950 and the i3 is heaps better than the 760K. Plus you can get like an i5-4460 down the road. If you have a bit more money a 280X is slightly more powerful.
I'm quite tired, so I'll probably mess it up, but normally I'd make a list for you - I'm sure someone else will. All I'll say is you don't want to go with AMD for your CPU...
Plus, no point getting the GTX 950, it's at the most expensive price point it will be, it literally just released. Don't need to spend that much on windows either. Do you NEED wifi?
#RIPTopGear  This is the best thread ever: http://linustechtips.com/main/topic/53190-i-can-not-get-hard/ " French meetings are just people sitting in a semi-circle shouting at each other" -Dom Jolly  :lol:
My rig:
   CPU: Pentium G3258 @ 4.5GHz GPU: GTX 760 reference | PSU: Corsair RM750 Cooler: Cooler Master Seidon 120V | Motherboard: Gigabyte B85M D3H | Case: NZXT S340 White | RAM: 8GB EVO Potenza @ 1600MHz Storage: 3TB Seagate HDD, 60GB OCZ SSD, 620GB Toshiba HDD | Mouse: Steelseries Rival @1000 CPi |  OS: Windows 10 Pro Phone: iPhone 6S 16GB
http://linustechtips.com/main/topic/439354-why-nvidia/
whit the parts you chose and that budget, your raping my ass right now, and making me cry.
what state do you live in becuase newegg may kill your budget, if you live in the taxable areas.
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor  ($70.89 @ OutletPC)
Motherboard: Gigabyte GA-F2A68HM-DS2H Micro ATX FM2+ Motherboard  ($48.99 @ SuperBiiz)
Memory: Kingston Beast 8GB (2 x 4GB) DDR3-1866 Memory  ($51.99 @ Newegg)
Video Card: EVGA GeForce GTX 960 2GB SuperSC ACX 2.0+ Video Card  ($194.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($88.88 @ NCIX US)
Total: $764.69
Generated by PCPartPicker 2015-08-23 19:16 EDT-0400
just did a real quick build, thought this was a little better. Oh forgot to put it on too, but I'd go WD for the HDD
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
Total: $692.38
Is this a reliable way to get windows? Like it's not a scam or anything?
Nope, perfectly fine. A lot of people on here get Windows that way. Make sure to read the comments on the thread to make sure, most if not all are legit. A lot of the guys on there will give another key if the first one doesn't work or something, too.
Here you go my man:
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($96.89 @ OutletPC)
Motherboard: ASRock 970 Pro3 R2.0 ATX AM3+ Motherboard  ($56.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory  ($54.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.98 @ Best Buy)
Video Card: Sapphire Radeon R9 380 4GB Nitro Video Card  ($223.98 @ Newegg)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($54.99 @ NCIX US)
Total: $771.75
Generated by PCPartPicker 2015-08-23 19:23 EDT-0400
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
Get Windows 7 off of reddit for like 10 bucks or just torrent the OS of your choosing like I did.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($176.95 @ SuperBiiz)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($42.89 @ OutletPC)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($44.99 @ Micro Center)
Video Card: PowerColor Radeon R9 290 4GB TurboDuo Video Card  ($229.99 @ Newegg)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($51.98 @ Newegg)
Total: $750.43
Generated by PCPartPicker 2015-08-23 19:25 EDT-0400
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory  ($53.89 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($47.78 @ OutletPC)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($34.99 @ Newegg)
Total: $750.43
needs bios update
Okay, but I always get nervous about things like that can you, if it's not too much trouble, recommend a reliable seller to me?
The one with the most comments seems to be the most popular one. Wait for him to PM you, I'm pretty sure you can pay him with PayPal or Google Wallet.
https://www.reddit.com/r/microsoftsoftwareswap/comments/3ht0hs/h_windows_10_7_8_81_servers_office_visio_project/
Texas
I'm in Houston!
I'm in Houston!
Nice, I live in Dallas! and thanks for the help!
psu review:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story4&reid=214
1ms, 60 hertz monitor
Memory: Patriot Signature 8GB (2 x 4GB) DDR3-1600 Memory  ($36.99 @ NCIX US)
Video Card: MSI GeForce GTX 950 2GB Video Card  ($158.99 @ SuperBiiz)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($43.99 @ SuperBiiz)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($51.98 @ Newegg)
Monitor: AOC E2476VWM6 60Hz 23.6" Monitor  ($129.99 @ Micro Center)
Keyboard: Logitech Corded Keyboard K280e Wired Standard Keyboard  ($9.99 @ NCIX US)
Mouse: Gigabyte GM-M6800 Wired Optical Mouse  ($14.77 @ Newegg)
Total: $794.42
Generated by PCPartPicker 2015-08-23 20:38 EDT-0400
BigDay
