This is my first tentative build.
http://pcpartpicker.com/p/kVJsNG
Any suggestions?
With a 1k budget you can do an i5, 380, SAMSUNG not kingston SSD, a Supernova (PSU) and no need for extra fans and fan controller :U
Gotta eat I'll redo the best build you can do in a sec
https://linustechtips.com/topic/436174-first-build/#findComment-5846420
This what I would do for 1k:
PCPartPicker part list: http://pcpartpicker.com/p/2cK6zy
Price breakdown by merchant: http://pcpartpicker.com/p/2cK6zy/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.99 @ Directron)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($125.99 @ SuperBiiz)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($43.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($47.78 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($337.99 @ NCIX US)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($54.99 @ Micro Center)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Total: $1016.70
Generated by PCPartPicker 2015-08-23 16:45 EDT-0400
Or you can switch out the gtx 970 for an amd r9 290x/390
~Man is least himself when he talks in his own person. Give him a mask, and he will tell you the truth - Oscar Wilde~
https://linustechtips.com/topic/436174-first-build/#findComment-5846452
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($176.95 @ SuperBiiz)
Motherboard: ASRock H97 PRO4 ATX LGA1150 Motherboard  ($81.89 @ OutletPC)
Case: Corsair SPEC-03 Red ATX Mid Tower Case  ($69.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($18.75 @ OutletPC)
Other: Windows 7 Pro ($25.00)
Total: $1005.41
Generated by PCPartPicker 2015-08-23 16:46 EDT-0400
Get windows from /r/microsoftsoftwareswap
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/436174-first-build/#findComment-5846464
CPU Cooler: be quiet! PURE ROCK 51.4 CFM Sleeve Bearing CPU Cooler ($34.90 @ Newegg)
Motherboard: MSI Z97-Gaming 3 ATX LGA1150 Motherboard ($125.91 @ Newegg)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR3-1866 Memory ($44.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.98 @ Best Buy)
Video Card: Gigabyte Radeon R9 390 8GB SOC Video Card ($328.99 @ SuperBiiz)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case ($99.99 @ Micro Center)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($73.99 @ SuperBiiz)
Total: $986.64
Generated by PCPartPicker 2015-08-23 16:49 EDT-0400
Get windows of g2a. You don't need more case fans, Atleast yet. I'll explain each part or why I chose certain parts if you want.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/436174-first-build/#findComment-5846512
you can save money by getting a 500w psu and by getting a windows key off g2a for like $25 bucks. i would get a better amd cpu like an 8350. 6300s are comparable to i3s
Even fx8s are comparable to i3s in cases for gaming. The fx6 or fx8 would also hold back the gtx 970 or 390. Not to mention to overclock the sucker you will need s high end CPU cooler and mobo.
https://linustechtips.com/topic/436174-first-build/#findComment-5846525
