Cpu help!
Go to solution Solved by FilipSebik,
Change power plan to Full Speed or High Performance in control panel-on windows 10 Win+X and choose control panel
Having problems with a brand new i5 4690k. I just installed windows 10, but the problem started before then. It is only running at .80ghz. Im using a seidon 120v cpu cooler.
What motherboard? And what BIOS update on it?
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/436166-cpu-help/#findComment-5846338
CPUs downclock themselves when there's little to no load to save power.
My i3 is at 1.7GHz right now with 6 programs open, just for an example.
THIS
ignore what everyone else is saying
If you want to fix it, go into power options, click the down arrow
and select High Performance, If it still doesn't work go into the Bios and disable speed step
https://linustechtips.com/topic/436166-cpu-help/#findComment-5846395
