CSS HELP!
Go to solution Solved by viliuks,
Oh I see your problem I think, in the second picture you have il not ln when it decorates as underline
Try this in your CSS:
html p{font-weight: bold;}
EDIT: this makes all the text inside a <p> bold though.
If you want all <p> text inside the lists to be bold use this in your CSS:
html li p{font-weight: bold;}
(I think that should work)
https://linustechtips.com/topic/435939-css-help/#findComment-5843195
