From the case cables we can see 5 fan headers, what am i suposed to do with them? :S
Plug them fans in and use yer damn fan controller! :P
what this guy said ^
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
Thanks! I was mounting them on the motherboard.
Should I connect all the fans including the cpu one or should I leave it on the mobo?
Thanks a lot again!
Your CPU fan header is on your motherboard near your CPU socket. The fans attached to the case can be plugged in to the case's included fan controller.
I'm using an aio water cooler btw
Plug the AIO cooler's pump into the CPU header and the radiator fan to the AIO's fan connection ideally, all the other case fans if you want to manually control them you can plug it into the case's controller or the motherboard if you want temperature based fan curves via the BIOS or software they have.
Ohhhh, OK, well I am pretty certain that Corsair AIO coolers have a header to plug into the CPU fan header but I could be wrong. The fans on the radiator should be plugged into the motherboard or the fan controller.
