Hey guys, This build is basically done. All I need is the MSI R9 390 and I will have that in a few weeks :) Im so excited!
I was just wondering what you guys think of the build and If you had any recommendations for a boot SSD and any comments you might have on the name of the build or any components that I decided to get.
Thanks!
Build: https://pcpartpicker.com/user/DrMacintosh/saved/LwgH99
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/435723-my-first-build/
this ^^
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/435723-my-first-build/#findComment-5840299
it is a nice gpu but same time it kicks out quite some heat especially for a itx build tho. Just my opinion as im using a 390 too.
CPU:  i7 4770k @ overclocked to 4.4ghz             GPU: Intel HD4600        SSD: Kingston V300 120GB (OS)                   Cooler:  Corsair H100i GTX
Case: Phanteks Enthoo Evolve (Black)                RAM: 2x4gb Corsair Dominator Platinium 2133mhz  HDD: 1TB Seagate                                            Mouse: Logitech G502
OS:     Windows 10                                                      PSU: Corsair RM850i 80+ Gold                                          Motherboard:  AsusZ97 Pro Gamer              Keyboard: Vortex Pok3r 3
https://linustechtips.com/topic/435723-my-first-build/#findComment-5840353
I really don't see a benefit to that EVGA PSU. But that SSD maybe. Maybe something a little smaller like a 120GB. I found one from Kingston for ~$50
https://linustechtips.com/topic/435723-my-first-build/#findComment-5840356
Heat isn't a problem. The case has excellent airflow and I modified my desk quite heavily.
post-229478-0-54241900-1440299476_thumb.
https://linustechtips.com/topic/435723-my-first-build/#findComment-5840421
But the heat will transfer affect your cpu tho especially if you are air cooling your cpu. I have custom loop on my cpu air cooling on gpu but it still increase around 5 to 10 degrees when gpu is fully loaded. Note i am using a huge case. Just a small reminder cause i saw some small itx build cpu reaches around 80 to 85 even with a 970. but 390 is a beast card ofc i love it so much now.
https://linustechtips.com/topic/435723-my-first-build/#findComment-5842243
A nice water cooling system might be good for the CPU. I will look into it
https://linustechtips.com/topic/435723-my-first-build/#findComment-5845283
