Wi-fi difference
so if its a 3-way one must be up and the other two 90 degrees from the middle right
With best practice, all 3 parallel. But thanks to CSMA/CA (carrier sense multiple access with collision avoidance), your computer and access point (most commonly called the router in home-use scenarios) will detect when a packet is lost/dropped/etc and will re-transmit (insanely simplistic explanation). This all happens in a fraction of a second, but does happen more often than wired (regardless of "proper" setup of the NIC antenna).
In reality, orient the antenna any way you care to, and you'll be fine and notice no difference from "proper" orientation. Mine on my desktop are set kind of like | / _ (with the last one more at 22*, but there's no slash for that.. lol) because there are cables in the way that are a little necessary for use on my computer. I have zero issues and the same amount of packet loss as the "proper orientation" (ex. | | | ).
Hope that helps some and wasn't too much.. I can get a little excited about the topic ![]()
