Hello , Im buying the S340 case which has 9 standoffs but the Asrock Z170 Extreme4 motherboard has 10 holes for standoffs. What should I do? Will it fit?
CPU: AMD Ryzen 5800X GPU: Nvidia RTX 3080 12GB + Motherboard: Asus Crosshair VIII Hero
  Case: Asus ROG Strix Helios Gundam Edition Power Supply: Asus ROG Thor 850P
https://linustechtips.com/topic/435482-s340-case-issue/
it has holes and additional standoffs... yes it will fit, you will just have to screw one standoff in.
https://linustechtips.com/topic/435482-s340-case-issue/#findComment-5836630
It will fit.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/435482-s340-case-issue/#findComment-5836634
the middle one is a standoff for holding the motherboard in place and it probable fill fit since its a standard ATX motherboard so just leave one empty i currently have my motherboard missing two standoffs and i have no issues
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/435482-s340-case-issue/#findComment-5836640
Do I need to buy extra standoffs?
No the case comes with a extra standoffs and a remover
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/435482-s340-case-issue/#findComment-5836713
