graphics card wont fit into motherboard it wont click or fit properly it doesint go all the way into the pcie 2.0 x16 slot
then you have something wrong in how you mounted the motherboard to the case
unless you are just doing something wrong?
is there a clip on the pci-e slot?
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/435228-help-graphics-card-wont/#findComment-5833289
nevermind i press slightly hard then what i was comfortable with and it went in thanks though for offering help
The first time it is always hard to install your new components, I remember the time I tried installing my i7-4790k into my first gaming pc, I thought it was incredible the amount of force needed to put the socket arm into place, I thought I was going to bent all the pins, I was sweating lol.
https://linustechtips.com/topic/435228-help-graphics-card-wont/#findComment-5833370
^this, now I take out the gpu with no regard for safety whatsoever. "Do as I say, not as I do".
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/435228-help-graphics-card-wont/#findComment-5833447
