None of them will be silent unless you will find one with noctua fans. Try and look for a single big fan as they tend to run at lower rpm and make less nois oppose to small ones. You can find some on ebay for abuot 10 dollars
EVGA SR-2 / 2x Intel Xeon X5675 4.4Ghz OC / 24GB EEC 1800Mhz OC/ AMD RX570 / Enermax Evoliution 1050W / Main RAID 0: 2x256GB 840EVO SSD / BackUp(1) Raid 5: 3x2TB WD HDD / BackUp(2) 8x2TB / Dell U2412M / Dell U2312HM
https://linustechtips.com/topic/434368-technically-air-cooling/#findComment-5821589
The Coolermaster Ergostand III is actually quite decent, you can set the fan speed using a knob so you can choose between silence and cooling performance.
https://www.youtube.com/watch?v=eavgniQyrFk
This one vs the cooler master notepal 3. I saw both of them but I didn't know what to choose
https://linustechtips.com/topic/434368-technically-air-cooling/#findComment-5821622
Found another two stands that look very interesting.
But you have to do some research on your own if you like the looks of it.
NZXT Cryo X60
Zalman ZM-NC2000NT
I looked at both and I think the cooler master one that jay reviewed seems to be the best
https://linustechtips.com/topic/434368-technically-air-cooling/#findComment-5821700
I made a similar thread not that long ago: http://linustechtips.com/main/topic/388416-best-notebook-cooler-2015-edition/
The result (at least for me) was: There is no perfect product out there, some interesting concepts like the Xpad, but not "the one cooler".
But I think the Ergostand III gets pretty close. ;)
https://linustechtips.com/topic/434368-technically-air-cooling/#findComment-5821702
