I started folding and i need some help.
Solved by Whaler_99,
Ya, I cannot tell what core you have for the GPU slot - most likely a 16 if you have just started. Review the FAQ and ensure to add the client-type advanced flag to get access to Core17 projects - no guarantee though... just luck of the draw. But, having an NVidia card should get you consistently higher PPD then AMD on non Core17.
Also, let them settle in a bit before you start looking at PPD - intially the FAH client can be messed up on calculating it. Typically the PPD "guess" is no where near accurate during the first few % marks...
