http://m.ebay.com/itm/231450997561?_mwBanner=1
Is this the one linus posted on his Instagram? I mean not exact same one but at least it works the same way?
I will like to try to flip my gpu around too is this gonna work?
I bought a cheap one just to test out whether it works or looks nice and appealing or not if this is a bad quality one I will get a good quality one after this.
Thx guys!
CPU:  i7 4770k @ overclocked to 4.4ghz             GPU: Intel HD4600        SSD: Kingston V300 120GB (OS)                   Cooler:  Corsair H100i GTX
Case: Phanteks Enthoo Evolve (Black)                RAM: 2x4gb Corsair Dominator Platinium 2133mhz  HDD: 1TB Seagate                                            Mouse: Logitech G502
OS:     Windows 10                                                      PSU: Corsair RM850i 80+ Gold                                          Motherboard:  AsusZ97 Pro Gamer              Keyboard: Vortex Pok3r 3
https://linustechtips.com/topic/433264-guys-need-a-little-help-please/
It should work.
but it does look hideous.
It looks like an IDE cable.
What is ide cable? I just find the one that looks most alike.
before SATA was the standard for data transfer in drives and readers, IDE was the thing.
sometiems a single cable would connect to your motherbaord on one port, and have two drive/reader ports, and you'd have to configure one as master and one as slave to set up priority.
Watch out for each other. Love everyone and forgive everyone, including yourself. Forgive your anger, forgive your guilt. Your shame. Your sadness. Embrace and open up your love, your joy, your truth, and most especially your heart.
-Jim Hensen
Oh the horror of cable management using IDE cables. GOD PLEASE NO NEVER AGAIN I'M GOING TO KILL MYSELF IF I HAVE TO EVER DO IT AGAIN
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
what are you using it for?
chances are its gonna work.
and by chances are i mean theres very littel chance of there being a reason it wouldnt. its just a ribbon cable extension of a port.
got that nice biege-grey ribbon cable colour. <3  i wish i had a can of that as paint.
-Jim Hensen
i always separated the indiviaual cables and sleeved them then re-connected them to the connectors.
you could buy IDE cables pre-sleeved but it was actually a hobby of mine since it took me so long. (also usually it was rather stiff sleeving so it wasnt as easy to manage)
-Jim Hensen
Don't know how to explain well in words but is like facing the fan side of gpu towards the window so I can see it. I'm having the strix dc3 to me that is one of the best design I will be glad to be able to look at it instead of the side led and heat pipe.
IDE cables are like the old SATA cables
Guess I'm too new for all this haha.
In what modern electronics do you still use that. Damn that thing is hideous.
Nodding so that my gpu face the front.
This.
Also, OP forgot to mention the gals on the forum.
gals?
Gals = Girls
(They are a protected species on the forum)
have not met any of them yet after 500++ post most probably i always say guys... Damn...
It's how we used to connect hard disks and pick up chicks in the 90's. It was pretty awesome.
that is hideous af.
