Yeah I'm looking for the best mouse so I can have the most FPS when I'm playing my games...
LOL JK, I'm just looking for a good mouse for First Person Shooters. Mostly for CS:GO but I'm also thinking about trying Battlefield.
My Baby Girl ❤️CPU: Ryzen 7 3700X | Mobo: ASRock B450 Pro4 ATX | RAM: 2 x 8 GB DDR4 3200 MHz GPU: EVGA GTX 1070 SC | Case: Fractal Design Core 3500 | HDD: Seagate 1TB SSD: Adata SP900 512GB PSU: EVGA 650G 80+ Gold Full Modular | OS: Windows 10
https://linustechtips.com/topic/433091-best-mouse-for-fps/
Finalmouse
GPU: RTX 2080 Super        Keyboard: Corsair K70 MK.2 RGB
CPU: i7-9700K        MouseLogitech G PRO Wireless
RAM: 16 GB Corsair Vengance PRO                                                         Headset: Corsair HS70 PRO Wireless
PSU: CX650F        MousepadCorsair MM500 Extended 3XL
MOBO: Asus Prime Z390-A        ControllerDualSense 5
Case: Lian Li Lancool II        CameraCanon EOS M50
Monitor: Samsung Odyssey G5        CoolingCorsair H100i Platinum
The white Rabbit        MicrophoneTrust GXT 252+
https://linustechtips.com/topic/433091-best-mouse-for-fps/#findComment-5804945
by far the steelseries rival or corsair m65
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/433091-best-mouse-for-fps/#findComment-5804954
Add a ? to the end of your topic header, had me for a second. And follow you topics  ;)
 CHRISTIAN MEMBER
https://linustechtips.com/topic/433091-best-mouse-for-fps/#findComment-5804969
Roccat Kone XTD? Especially if you have big hands
I'm more looking for an optical mouse. I've heard laser mouses aren't really good for gaming because of cursor acceleration so it's hard to build muscle memory.
https://linustechtips.com/topic/433091-best-mouse-for-fps/#findComment-5805065
Mouse accelaration has nothing to do with a laser mouse. It's all in software and is the same for both laser and optical mice. Here is Linus's TechQuickie video: https://m.youtube.com/watch?v=16diwK6HWbI
It is possible to disable it with downloaded fixes.
https://linustechtips.com/topic/433091-best-mouse-for-fps/#findComment-5806306
It is about CPI Variance every optical system has, some like A9500 have more than what can be considered tolerable.
https://linustechtips.com/topic/433091-best-mouse-for-fps/#findComment-5806703
As far as I know there is an Optical version of the XTD, but it's very expensive.
Zowie is really good and pretty much all mice they make are great. There are various choices, so pick one based on weight and size. Make sure to measure your hand to get a better guide of what mouse to pick, and take your gripping style in account.
Laptop: Intel Core i5-4200H, 8GB RAM, 750GB HDD, GeForce 840M
Desktop: Intel Core i3-6100, 8GB RAM, 750GB HDD, GeForce GTX 750 Ti
https://linustechtips.com/topic/433091-best-mouse-for-fps/#findComment-5809549
You can get it in Optical. My friend has one, swears by it for tournament play. I wouldn't recommend it if you have small hands, though if I recall correctly it has adjustable weights, and starts out fairly light
CPU: Intel Core i7-4770k | Mobo: MSI Mpower Max | Cooling: Cryorig R1 Ultimate w/ XT140 front Fan | GPU: EVGA GTX 770 Dual SC SLI | Case: NZXT H440 | Case Fans: Phanteks PH-140SP x5 | PSU: EVGA Supernova P2 1000W | RAM: 16GB Crucial Ballistix Tactical Tracer | SSD: Kingston HyperX 3k 120GB | HDD: Seagate Barracude
Keyboard: Razer Blackwidow Ultimate 2013 | Mouse: Razer Deathadder 2013 | Headphones: Sennheiser HD438s | Mousepad: Razer Goliathus Control | Monitor 1: Benq XL2430T | Monitor 2: BenQ RL2455HM
https://linustechtips.com/topic/433091-best-mouse-for-fps/#findComment-5809679
Nah its 120+g, but it has good feet and obv. a lot of surface to grip on making it feel lighter than it is at slower movement speeds, however at faster swipes you can still feel it in your arm.
https://linustechtips.com/topic/433091-best-mouse-for-fps/#findComment-5809840
Ah, I couldn't remember what the default weight was. I didn't find it horrible to use. I've seen a lot of recommendations for the SS Rival tonight, and I can say that left me with cramps in my hand using one at a net cafe last week. So, preferences I guess
https://linustechtips.com/topic/433091-best-mouse-for-fps/#findComment-5809884
It all comes down to preference really. Each person will have a different opinion.
Honestly, I think hype about which mouse is better and whatnot is just stupid. I bought a G402 for $20 and am perfectly happy with it. Sure, there are probably some better mice out there, but only by a very small bit if anything.
https://linustechtips.com/topic/433091-best-mouse-for-fps/#findComment-5809904
