Anyone got a Corsair 900D air cooling build
Metro
Hello
Does anyone have a Corsair 900D air cooling build, most of them online have really low end components in it, some are really bad quality images.
Thanks
GPU[Two GTX 980ti Lightnings overclocked]-CPU[Core i7 5930K, 4.4Ghz]-Motherboard[MSI X99 Godlike]-Case[Corsair 780t Black]-RAM[32GB Corsair Dominator 3000Mhz Light bars]-Storage[samsung 950 Pro 512GB, Samsung 850 Pro 1TB and Samsung 850 Pro 512GB]-CPU Cooler[EK Predator 360mm]-PSU[EVGA 1600w T2 Individual cables Red]-Monitor[ASUS PG348Q]-Keyboard[Corsair K70 Red]-Mouse[Corsair M65 RGB]-Headset[sennheiser G4me one]-Case Fans[beQuiet Silent Wings 2]
You're probably not going to find many pictures of the 900D with air cooling in it because literally nobody buys a 900D and cools their system inside of it with air.
I actually couldn't underclock my 5 year old GPU to make it as slow as a next-gen console.
#pcmasterraceproblems
~Slick
ya, someone who is dumb enough to blow that much money on that case for air cooling
Why would anyone want a 900D for air cooling anyways
I have seen quite a few people do it.
literally the stupidest thing you could do
PEWDIEPIE DONT CROSS THAT BRIDGE
What would the point be? The reason to get such a large case is to allow for heaps of radiator support....
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
Well I mean with a H110GTX 280mm
That is still not much.
I agree but there is no Corsair case that is smaller than the 900D but bigger than the 750D, only the Corsair 800D but that has been discontinued
Correct, 800D has already been discontinued. if you are planning to use an AIO cooler like the H110i GTX, I think the 750D has a good amount of space inside to house the H110i GTX. Graphite 780T is also a good alternative. Otherwise, I honestly think 900D air cooled is not the way to go. Unless I am missing something here.
Did not expect a Corsair member response, I am currently looking at the 750D or 780t, I just cannot decide which one to get at the moment. If only you made a full tower C70, could you be making a C90
I will be using an MSI X99 Godlike, the 780t gives it a better view as the rear fan is back more than on the 750D
Also does the 750D have a more transparent window to it. The 780t seems to have a darker window on it.
[spoiler = "My Computer Stuff"]
My ITX:
240 Air ; Z87I-Deluxe ; 4770K ; H100i ; G1 GTX 980TI ; Vengeance Pro 2400MHz (2x8GB) ; 3x 840 EVO (250GB) ; 2x WD Red Pro (4TB) ; RM650 ; 3x Dell U2414H ; G710+ ; G700s ; O2 + ODAC + Q701 ; Yamaha HTR-3066 + 5.1 Pioneer.
Things I Need To Get Off My Shelf:
250D ; 380T ; 800D ; C70 ; i7 920 ; i5 4670K ; Maximus Hero VI ; G.Skill 2133MHz (4x4GB) ; Crucial 2133MHz (2x4GB) ; Patriot 1600MHz (4x4GB) ; HX750 ; CX650M ; 2x WD Red (3TB) ; 5x 840 EVO (250GB) ; H60H100iH100i ; H100i ; VS247H-P ; K70 Reds ; K70 Blues ; K70 RGB Browns ; HD650.
