Hey guys, I'm wanting it to print this
What is your favourite sport? tennis
That is my favourite sport too!
We should go play some tennis!
then if they answer something else I want it to print this
What is your favourite sport? soccer
We should go play some soccer!
this is what I have so far
name = input('What is your favourite sport? ')
if name == 'tennis':
  print('That is my favourite sport too!')
  print('We should go play some '+name+'!')
if name == 'soccer' or 'cricket':
but if they say tennis it prints the bottom line twice why is this?
https://linustechtips.com/topic/431101-learner-help/
Use elseif for the latter part.
name = input('What is your favourite sport? ')if name == 'tennis':     print('That is my favourite sport too!')  print('We should go play some '+name+'!')elseif name == 'soccer' or 'cricket':    print('We should go play some '+name+'!')
https://linustechtips.com/topic/431101-learner-help/#findComment-5780473
^exactly what I was going to suggest.
https://linustechtips.com/topic/431101-learner-help/#findComment-5780479
Isn't doing what you think it is. To check if name is either soccer or cricket you have to do
if name == 'soccer' or name == 'cricket'
or
if name in ('soccer', 'cricket')
The way you have it will always return true because 'cricket' evaluates to True and True or anything is True.
1474412270.2748842
https://linustechtips.com/topic/431101-learner-help/#findComment-5780522
It's elif, not elseif
Project Pluto
i3 4170 MSI H97 PC Mate MSI R9 380 2GD5T @ 1095MHz Kingston HyperX Fury Blue 2x4gb @ 1600MhzWD 1TB Blue • be quiet! Pure Rock • NZXT S340 Black XFX TS 550w • BenQ GW2265HM
https://linustechtips.com/topic/431101-learner-help/#findComment-5780526
