Water + ear cups
Solved by Lays,
ok,but does leatherette risk getting damaged if put quickly underwater?
No, its fine to rinse them off with a tiny bit of dish soap & water on a towel of cloth.
Just stay away from things like alcohol wipes, it will probably dry up the leatherette
If you live near an auto store, you could go in and ask if they have wipes for fake leather, and use those as well. Probably would only cost $5
