are you overclocking?
is the CPU voltage set to auto?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/429733-cpu-over-voltage-error/#findComment-5763044
So that didnt work. Is there a possibility there could be something wrong with either the Motherboard or the PSU?
are you able to boot to windows?
https://linustechtips.com/topic/429733-cpu-over-voltage-error/#findComment-5763304
Does this mean that the PSU is faulty?
could be check the PSU voltages using a Multimeter
https://linustechtips.com/topic/429733-cpu-over-voltage-error/#findComment-5763335
Would it be better just to ask for a replacement.
return it for a better model
https://linustechtips.com/topic/429733-cpu-over-voltage-error/#findComment-5763356
