Case Air Cooling Solution
Solved by Kuzma,
I have no use for it, I shall get rid of it then... Oh ya which fan do I put in the front, 200mm/140mm/120mm?
200mm, you can run it at a lower rpm and still get the same amount of air flow.
popularlion ·
Posted in Troubleshooting2 -
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1 -
BoBo6107 ·
R_public ·
Posted in Networking14 -
apoyusiken ·
Posted in PC Gaming1 -
6
