Water CoolingVS Air Cooling
Which do you guys prefer/have in your systems? i prefer water cooling :D
Water cooling at the high end is the only water cooling that is worth it. If you buy an AIO under like an h90 you are wasting some money for sure. However you can make the argument of looks. Custom water cooling is so insanely overpriced I will probably never do it. At the low end always go air if you don't mind looks. An evo212 has been cooling than a h50 that cost twice as much...
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
I use air personally, as my case is set up for it, but I would like to try watercooling when the coolermaster master case pro 5 comes out.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
I have an AIO.
I got one because they look nicer and it will be easier to transport a few times a year since there isn't as much strain on the mobo from a big heatsink.
High end air coolers will almost always cool better than AIOs.
PCPartPicker link: http://pcpartpicker.com/p/R6GTGX
Привет товарищ ))))
Air, my r1 ultimate beats a h100i for almost half the price, can't compete.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
I was thinking about going Water but currently running Air.  Maybe I will get a Water cooler for the CPU but that's about it, I don't really have any interest in a water loop.
i7 5820k, Asus Deluxe x99 3.1 board, 2 Strix980tis Sli, Intel 480gb SSD, 4T WD Black, Asus PG278Q, Acer xb271hu, UpDesk!
depends on my situation.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
I would probably prefer high end air instead of water unless I was building in a case with a side panel window and in an eaisly visible location. Right now I am using a stock intel cooler but I will buy a better cooler in the near future for less decibels whenever my hard drive turns off -- that thing drives me crazy!
I've been thinking noctua. A 212 evo just isn't worth it for me. I'd rather spend a little more or just stick with stock. My cpu temperatures at idle/web browsing are at 40c and I don't think they rise above 70c in game.
I like the simplicity of air cooling. I'm new to PC building though.
i5-4690K@4.5 GHz // Asus Z87-Pro // HyperX Fury 8GB DDR3-1600 // Crucial BX100 250GB // Sapphire Nitro R9 390 // EVGA SuperNOVA 750W G2 // Fractal Design Define S // be quiet! Pure Rock & Pure Wings 2 // BenQ XL2730Z // Corsair Vengeance K70 // Logitech G403 Wireless // Sennheiser HD 598 SE
Air cooling. If something goes wrong I know how to fix it easily plus Cryorig makes some sweet looking aircoolers.
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
Indeed. I wish they were available in Canada.
You stick with air and 120mm AIOs until you want to overclocking, and when you do you move to 240mm AIOs and custom loops.
Eien nante naito iikitte shimattar  /  Amarinimo sabishikute setsunai deshou
Dare mo ga hontou wa shinjitai kedo  /  Uragirarere ba fukaku kizu tsuite shimau mono
I went from a 212 to a 240mm aio and back to the 212 because i felt like it wasn't worth it for me. I just recently got a 2nd hand nh-d14 and it does about as well as my 240mm aio while staying quieter, for less money. If money was no problem then a custom water loop would be fantastic but i don't think that's a viable option for most
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
I run a Corsair H60 in my thin sff case, only because a decently tall air cooler wont fit.  If I had a choice though, I would still probably choose an AIO/water.  My H60 is completely silent, I have never heard any pump/water noise and it has cooled my overclocked 4690k perfectly.
If I did go air on my build though, I have been eyeing the Cryorig C1.
