Hi there.
I recently installed my CPU Cooler.
When I was installing it one of the connectors has broke (One in the picture bellow)
I was trying to put it into the motherboard connector hole, but it got caught on the motherboard tray and snapped but still connected to the cooler.
I then pushed it in and now its jammed.
After that it was fine, the CPU cooler was stable and wasn't moving, I applied pressure to make sure it was fully stable and it was in good form, except the broken connector.
Running it for over a week now and it's all good.
What should I do to be sure it doesn't fall or anything like that.
Is this a common thing to happen?
Thanks.
P.S Intel Connectors
Cpu Intel Core i7 (3770) 3.4GHz Qaud Core - MB MSI Intel B75MA-P45 - RAM Hypertec Hyperam 32GB - GPU EVGA Nvidia GTX 980 ti 8GB SSC - Case Cooler Master K-Series K380 Storage SSD 240GB Sandisk WD 1TB Caviar Blue - PSU EVGA 600W Bronze - Display BENQ 22' GL2450 - Cooling Cooler Master Hyper TX3 Evo
https://linustechtips.com/topic/427530-cooler-master-hyper-tx3-evo/
Ive installed 3 of them now and none of those connectors broke yet (maybe its because they look fragile --> i'm gentler :3)
And to prevent it from falling just take a piece of string or a ziptie and strap it between one of the heatpipes and the VRM heatsink or sth...
