IN/OUTPUT help..... or question
Solved by Napper198,
Any sound card with a optical output will work since digital sound is not affected by any cheap audio component. Maybe your Mainboard even has a header for that and you'll only need to buy a little daughter board that plugs into your mb. Check your mb's manual for that.
Edit: if your mainboard supports digital out through headphone jack you can also use a coax to optical adapter. Or you can get a HDMI audio splitter
Edit2: this CSL one seems to be the cheapest one that doesn't totally suck
