hi i have a dell dimension 4600 and it has two SATA pulgs on it and i was wondering if i could get a WD 500gb hard drive? and what is the difference between sata 1.5gb/s and sata 3gb/s?
[NEW System] (CPU) i7-4790k (mobo) ASUS maximins V (GPU) AMD R9 380x (CPU cooling) Corsair h100 (PSU) EVGA 800w (Monitor's) LG 32" ultrawide @ 75hz and a Asus 27" IPS logitech g602 mouse
[OLD System] (CPU) amd athlon x4 760k@ 4.4ghz/ (mobo) MSI FM2-A55M-E33/ (GPU) Gigabyte windforce 7870 / (CPU cooling) Corsair h100/ (PSU) Corsair CX 430w/ (monitor) dell 1980x1080@60hz 21"/ a logitech keyboard and mouse. Phone: Samsung S5  Galaxy s10e .
OLD Laptop: Dell Latitude E6410 with i5 520m and Nvidia NVS 310
Laptop's: Dell precision m2800 i7 4610m with amd firepro w4170m
other laptop Asus.
https://linustechtips.com/topic/42599-sata-help/
just the speeds are differnent,but if you use a regular hdd it would even come close to using the 1.5gb.
2500k 4.0ghz,GTX 1070 oc,MSI Z77A-GD55,G.SKILL Ripjaws(4 x 2GB)DDR3 1333,OCZ Arc 100 240gb,Samsung Spinpoint F3 1TB,Corsair TX 750w v1,CoolerMaster HAF 912,Hyper 212 EVO
https://linustechtips.com/topic/42599-sata-help/#findComment-555088
Not exactly bit something like this:
You can get the hdd as the connectors are backwards compatible.
https://linustechtips.com/topic/42599-sata-help/#findComment-555115
The speeds are different but the plugs are the same and SATA is backwards compatible so you could use a SATA 3 drive on a SATA 1/2 port. 1.5gb/s is SATA1 interface while the 3gb/s is SATA2.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/42599-sata-help/#findComment-555197
cool thanks can you recommend a good hdd? either a 500gb or a 1tb.
other laptop Asus.
https://linustechtips.com/topic/42599-sata-help/#findComment-557744
The Seagate Barracuda (2 year warranty) drives are affordable drives imo. But if you want high reliability, get a WD Caviar Black (5 year warranty) drive. But I have been using Seagate Barracuda drives for all my builds and have never lost a drive yet.
https://linustechtips.com/topic/42599-sata-help/#findComment-557791
