Guys is it worth running 4790k // 5820k with stock cooler or evo 212 without really much overclocking :/
Because if i go forLiquid cooler i want the best on the market if i dont i want nothing and the cheapest, thats who i am. ( Get rich or die trying ) !
Project Redline:
♦CPU: i7-5820k  ♦CPU Cooler: Kraken x61 ♦Mobo: MSI X99A SLI ♦RAM: G.Skill Ripjaws 4x4GB 3200mhz ♦GPU: Evga 980Ti Hybrid ♦Case: NZXT H440 ♦SSD: Samsung 850EVO 500GB ♦HDD: WD BLUE 1TB 7200rpm ♦Display: 1280 x 1024
https://linustechtips.com/topic/425687-cpu-stock-cooler/
First off, the 5820k doesn't have a stock cooler. Secondly, a 212 evo will be decent for them, though won't give a ton of OC room. Finally, don't double post.
https://linustechtips.com/topic/425687-cpu-stock-cooler/#findComment-5712797
dont think you will be able to overclock at all with the stock cooler
isnt that the whole point of a k cpu?
hmm ya ur right ... i am posting something at gpu section too i have to do hard decision !! AND I HATE HARD DECISIONS !!
Project Redline:
https://linustechtips.com/topic/425687-cpu-stock-cooler/#findComment-5712840
Don't underestimate the 212 EVO. It's almost 7 inches tall FFS! Don't let the price fool you. Also the 5820k doesn't come with a stock cooler, the 212 EVO will work great
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/425687-cpu-stock-cooler/#findComment-5713123
i had a noctua on my 5820k and it caped out right around 1.25v.
wat? Your cooler... capped your voltage?
https://linustechtips.com/topic/425687-cpu-stock-cooler/#findComment-5713140
212 is just too good for the price. If you're cash-strapped there is no other choice.
It's also quieter than the stock cooler..
"If a Lobster is a fish because it moves by jumping, then a kangaroo is a bird" - Admiral Paulo de Castro Moreira da Silva
"There is nothing more difficult than fixing something that isn't all the way broken yet." - Author Unknown
Intel Core i7-3960X @ 4.6 GHz - Asus P9X79WS/IPMI - 12GB DDR3-1600 quad-channel - EVGA GTX 1080ti SC - Fractal Design Define R5 - 500GB Crucial MX200 - NH-D15 - Logitech G710+ - Mionix Naos 7000 - Sennheiser PC350 w/Topping VX-1
https://linustechtips.com/topic/425687-cpu-stock-cooler/#findComment-5713147
cooler doesnt control voltage, are you saying your temps hit the limit at that voltage with that cooler(which noctua??? there are so many)?
https://linustechtips.com/topic/425687-cpu-stock-cooler/#findComment-5713153
^ dizs
the avg temp was fine on the noctua air u14s cooler but it would spike past 85C so I couldn't increase the voltage further safely.
https://linustechtips.com/topic/425687-cpu-stock-cooler/#findComment-5713159
^ dizs
the avg temp was fine on the noctua air cooler but it would spike past 85C so I couldn't increase the voltage further safely.
I don't think that's normal... I had a 5820k under a 212 evo that wouldn't go past 72° but I didn't overclock I guess
https://linustechtips.com/topic/425687-cpu-stock-cooler/#findComment-5713176
stock voltage is about 1.
n you should overclock. you get a 20%+ gain going from stock to 4.4ghz.
It's a computer I built for my grandma. She wanted to play the Sims 3. (No I didn't pick out the parts)
https://linustechtips.com/topic/425687-cpu-stock-cooler/#findComment-5713223
that really doesnt sound normal... I have one of the most pitiful water coolers in existence and a chip with a bad TIM between the die and heat spreader and I'm running at 1.272V at 80C tops
and its a consumer grade chip... a 3570K
https://linustechtips.com/topic/425687-cpu-stock-cooler/#findComment-5713227
at least it's gonna be future proof for about 10 yrs.
the mainstream lga 115x chips use a much smaller die than the enthusiast grade lga 2011 chips. look at the power consumption figures for haswell-e and you'll see what kind of beasts they are overclocked.
https://linustechtips.com/topic/425687-cpu-stock-cooler/#findComment-5713268
