I plan to be playing triple-A titles on 5760x1080p resolutions.
I am planning on getting two 4GB ASUS 770s for SLI (i will be overclocking), i had a chance to play around with dual 770s and they perform very well.
What other solutions (if any) should i consider in that price range?
CPU: i7 4770k @ 4.8Ghz, MoBoROG Maximus VI Formula, Graphics Cards: Dual MSI 4GB@8.5GHz Nvidia GTX 770@1.3GHz , Memory16GB Kingston HyperX @2.4Ghz Boot Drive: Samsung 840 Pro 256GB, Storage: RAID 0: Seagate Barracuta x2 4TB, PSU: Corsair GS 800, Cooler: Corsair H100i, Case: Antec P280 Peripherals: Triple ASUS VH238H 1080p monitors (5760x1080p), Razer Mamba, Razer Black Widow Ultimate, Razer Orbweaver, Steelseries H Wireless
Laptop: ASUS G750JW: CPUQuad-Core i7 4th Gen @3.4Ghz, Memory12GB memory, Storage: 1.5TB Hard Drive (1TB + 500GB), GPU: GTX 765m 2GB-GDDR5
https://linustechtips.com/topic/42536-best-graphics-solution-for-1000/
3 x 7970's? :P
I'm kidding. 2 770's sound good.
That's actually a really good choice, the 4GB of VRM will help with the multi monitor setup. You could go dual 7950 but you'll lose 1GB of VRM.
Me: Yeah I just really can't get my H220 working again, I've tried everything that was suggested in the forum.
Brian (Swiftech Support): Hmm, have you tried slapping it?
TITAN is the best. Yes it may get beat by two 770s. But TITAN has all that power available to it at all times. While SLI based rigs need to have SLI optimized games to take advantage of the power. If you happen to play a game that doesn't like SLI, your TITAN beating performance will be gone, and you'll rely on only one GPU.
my vote is for 7990...
dual gpu on one card with a wide memory bus. AMD does pretty darn well at high res
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
But the titan struggles a bit with 3 monitors
<p>Wires Suck :angry:
!fY0|_|(4|\|R34[)7#!5PMM37#3(0[)3:1337 70833|\|73R3[)!|\|49!\/34\|/4Y 4|\|[)93741!f3
Then again, i have yet to find a triple-A title that /isn't/ optimized for SLI or Crossfire, and anything else won't really need more than one 770, right?
+1 Or 9970 if there cheap enough
 Asus M5A99X Evo  - AMD FX-8350 - 16GB Corsair Vengeance 1866Mhz - Corsair 120mm Quiet Edition Fans BenQ XL2411Z- EVGA GTX 980 Superclocked Fractal Design Define R4 - Corsair H100i - 2 TB 7200rpm HDD - Samsung 840 Evo 120GB - Corsair RM750w PSU - Logitech G502 Proteus Core - Corsair K70 RGB MX Red - Audio Technica M50x + Modmic 4.0 - LG 23EA63V x2
Spinthat Spinthat Spinthat Spinthat
if the 9970 follows standard AMD launch prices then you can probably grab 2 for $1150
AAA titles may support SLI. But people have been having issues with SLI in BF3, which is AAA.
Yes, but anything slightly more powerful than it will struggle a bit as well.
well i am upgrading from dual 660tis and battlefield is my most played, and i have never had a problem, but irregardless.
It appears to be with the 700 series cards. Maybe you won't be affected.
STOP DO NOT BUY THE 4GB 770 unless you are going 3x SLI!! YOU WILL NOT BE ABLE TO TAKE ADVANTAGE OF THE EXTRA 2GB OF VRAM DUE TO THE MEMORY BANDWIDTH!!
._.
Console optimisations and how they will effect you | The difference between AMD cores and Intel cores | Memory Bus size and how it effects your VRAM usage |
How much vram do you actually need? | APUs and the future of processing | Projects: SO - here
Intel i7 5820l @ with Corsair H110 | 32GB DDR4 RAM @ 1600Mhz | XFX Radeon R9 290 @ 1.2Ghz | Corsair 600Q | Corsair TX650 | Probably too much corsair but meh should have had a Corsair SSD and RAM | 1.3TB HDD Space | Sennheiser HD598 | Beyerdynamic Custom One Pro | Blue Snowball
._.
well what, do you expect me to get a 2gb version? even if it cannot utilize all of the memory (which i doubt), it can still utilize enough to make it worth it.
edit: besides, i am probably going to upgrade to 3xSLI eventually.
It wouldn't be worth the extra price at all; you'd get less than 3gb (around 2.4-2.6 depending on the OC you get on your memory clock).
do you have any proof?
so 2gb won't be enough, if his budget allows why not
The SLI 4GB GTX 770s will probably give you the best performance for $1000 for now except maybe 3 7970s which would probably take a lot more power and run hotter
[spoiler=Current Rig:]i5-4670K @ 4.4 Ghz on 1.3v | MSI Z87I | GTX 780 @ 1150 Mhz | 2x8GB ADATA XPG | Samsung 840 250GB SSD | CM V700 PSU | Custom Watercooled in a Caselabs S3
[spoiler=Peripherals:]Mad Catz R.A.T. 7 | Corsair K70 | Sennheiser Urbanite headphones | Corsair Vengeance MM200 | Asus PB278Q + Samsung 22"
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
alright, thanks, but i still think i'll take the 770s, especially since their memory bus is so much faster than that of the 680s.
It's not THAT much faster than the 680, feel free to get the 770s but when you run into VRAM issues you'll know what you should have done ;)
