Hi peeps of folding!
Here are my 2 issues:
1. Ok, so on my F@H page, it says I have earned 32 (right now) WU (I didn't), but when you click on certificate it says I only completed 27 (right). If you scroll down it also says I completed 76 WU for another team, but when you click on certificate, it says 2 (again, this is the right number).
2. My F@H control thing says I make around 57k PPD on my GPU and 40k PPD on my CPU. Folding from 7-11 doesn't even get close to this (Maybe like 15k for every 16hrs). Also, the gpu says 57k PPD, but it takes around 6-8 hours per WU, while my CPU only takes 1-2 hours. The CPU is better, but getting getting less PPD? WHAA?
Anyways, I'm not getting close to the ~100k PPD that I am promised. Any my gpu is not living up to what it promised.
Specs BTW:
750ti (some pretty high oc)
5820k (4.4GHZ) actually 4.0 right now
16gb 2800mhz
Thanks alot for your help!
-nicon
P.S. Sorry about bugging this topic with all of my problems. Like seriously, I shouldn't be doing this.
https://linustechtips.com/topic/424959-weird-wu-and-points-incorrect/
Well.. there is alot to tackle at once here. let's start by addressing the ppd. The ppd is a future estimate/prediction
based on what you are doing right now. The ppd assumes you will continue like you currently are for 24 hours.
However, if you finish/pause or get different a wu, something changes in between, that prediction will be wrong.
You also receive bonus points, the quicker you return a wu the more points you get, the slower you return a wu
the less bonus points you will receive. the ppd or point per day estimate will not be on target when you fold for 4
hours a day, the ppd will also change(decrease) as will the points you are awarded when you resume folding after
pausing a wu for a extended period of time. This is because of all the time lost when you weren't folding.
When it comes to cpu and gpu wu's. Not only gpu/cpu but also wu's in general vary in size. Your cpu isn't necessarily
"better" just because it finishes a small wu faster.
As for the certificate, i currently can't view it. But get yourself a passkey to properly identify you, the certificate is bound
to update eventually.
