Hello,
I'm having some problems with my new X99 motherboard.
Specs:
-5820k
-Gigabyte X99 UD4P
- HyperX Fury 2666mhz cl15 1.2v
-Super Flower Platinum 1600w
I can't get my memory to run at it's rated speed 2666mhz cl15 1.2v. If I enable XMP profile my DRAM voltage will be set to 1.4V and I'll randomly get this message. If I try to use 125 strap I'll get the same error.
post-80418-0-18975700-1438879458_thumb.j
If I manually set DRAM voltage to 1.2v I'll get that error every time I try to boot. I can run 2400mhz without any problems.
My bios randomly freezes. It will just get stuck and I have to press reset or hold power.
When I use any gpu intensive application I'll hear electrical noise from my headphones (NOT coil whine. It's NOT coming from gpus them selves)
https://linustechtips.com/topic/424664-x99-motherboard-problems/
