Hi guys!
I've been following LTT for a while now and I've decided that I'm going to venture into building my own rig, I've settled on the following specs and was wondering if you could tell me how they will perform in terms of modern gaming on Ultra Settings at 1080p? and maybe if you could suggest some changes?
CPU: Core i5 4590
GPU: Nvidia GeForce GTX 970
MoBo: Gigabyte H81M-D2V
Case: NZXT Phantom 240
PSU: Corsair VS-650w
RAM: 16GB Kingston Hyper X Fury 1600MHz
Storage: 1TB WD Black 7200rpm HDD
Cooling: Corsair H60 Hydro Series
How do you think this will perform guys?
https://linustechtips.com/topic/424525-building-my-first-pc/
no real need to go for an h60 with a lock cpu. i would probably replace that h60 with an ssd.
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/424525-building-my-first-pc/#findComment-5698692
Pretty much what he said, no real need for after market cooling on a stock clocked CPU
https://linustechtips.com/topic/424525-building-my-first-pc/#findComment-5698712
Sorry I forgot to mention, I've got a Samsung Evo 850 120GB SSD as well
Hi guys!
CPU: Core i5 4590
no need for that cooler. The stock is more than enough. It can get loud though.
https://linustechtips.com/topic/424525-building-my-first-pc/#findComment-5698736
Will the H60 operate much quieter than stock? If so I may stick with it for when I get a k series processor later on a delve into overclocking
How much does the cooler cost? Also, you could that money onto something better.
https://linustechtips.com/topic/424525-building-my-first-pc/#findComment-5698799
I'm getting it discounted from a friend for £30, used once on a test bench, fully functional as new
How much does the whole system cost?
https://linustechtips.com/topic/424525-building-my-first-pc/#findComment-5698862
