I know I need the new thermal paste itself, microfiber cloth, and isopropyl alcohol. But if I didnt have the cloth and/or the isopropyl alcohol. What could I use as a suitable replacement?
I7-6700k, Asus Maximus VIII Formula, 2 x 8GB Corsair Dominator Plantinum ram, ASUS GTX 960 STRIX, sound blaster zx, 1TB boot drive ssd, 128GB/256GB storage ssd, 1TB storage HDD, 4TB of storage (backup),Windows 10 Pro,1000w psu
that thing work wonders, it's so shiny afterwards xD
Check out the build: Used to be Obot, now Lilith
Shameless: Me
Instead of a cloth you could use some toilet paper.
Cloth is better, as you won't have to do deal with lint. But toilet paper/paper towels would still work.
You can take a drive to a store and buy both. ;)
And if you're lucky, you may even to be able to get both in the same store!
Use coffee filters..they are lint free, and isopropyl alcohol.... use filters until it is clean...no residue. This will prep your cpu for TM....
<p>CM HAF 922 (Akasa Apache 140s/120s for case cooling), ASUS Sabertooth Z77, Intel 3570K@4.0Ghz, 16GB Kingston Black @1600 (2x8), Xigmatek DK 2 with 2 xAkasa Apache 120mm, Sapphire 7950 OC CF, NZXT Sentry Mix 2 FC, 2TB Seagate Barracuda HDD x1, Kingston Hyper X 240GB SSD x1, Seasonic 1050w PSU, Cyborg V5 Keyboard with RAT 3 mouse, ASUS VG248QE 144mhz. monitor
