Hi Everyone,
I built my first gaming PC and the temps in my case seem pretty warm. I think the higher temps are primarily because of the restricted air flow of the case (H440) and I'd like to know what I can do to better cool things down. I tested my temps while playing Tomb Raider at max settings for about 30 minutes. My GPU (MSI 970) reached 74C and my CPU (4690k) reached about 72C. Temperature in the room was about 84F. Both CPU and GPU are at stock speeds. CPU is using the stock fan.
What would be the best option for cooling down my system?
Install aftermarket CPU cooler such as Hyper 212 EVO (btw - will this help blow heat from the GPU out of the case)
or
Install 2 or 3 top case fans as exhaust (Would I need a special type of fan since the top of the case only has side openings?)
GPU: MSI 970
CPU: 4690k (stock speeds/ fan)
Case: H440
https://linustechtips.com/topic/423063-h440-cooling-options/
those temps are fine, the gpu temp is good for load, the cpu temp is as expected with a stop cooler. if you want to over clock it then get a better cooler.
as for a cooling upgrade i would get a 2x120mm radiator all in one for the cpu and mount it as exhaust on the top
https://linustechtips.com/topic/423063-h440-cooling-options/#findComment-5680911
Not sure how much 2 exaust fans would help with  those side openings. 212 should help with exaust since all hot air from cpu would go straight to back fan leaving case with more cool air.
CPU: i7 4790k @ 4.4 GHz                                                 Case: Fractal Design Define R5                       SSD: Samsung Evo 850 250gb          Monitor:  Benq GL2760
   GPU: MSI GTX 970 SLI (+140 Core|+400 Mem)               Motherboard: Msi Z97-G5                                 HDD: WD blue 1TB                             CPU Cooler:  Hyper 412s
      RAM: 16GB HyperX DDR3 1600MHz                                PSU: Cooler Master v850                                 Storage: Adata HV610 1TB                  OS: Windows 10
https://linustechtips.com/topic/423063-h440-cooling-options/#findComment-5680950
Hi Everyone,
or
GPU: MSI 970
Case: H440
The GPU temps are totally normal. The CPU is running a bit hot, but within expected since it's using a stock cooler. Best investment in your case is a CPU cooler, airflow only does so much, i would recomend a cryorig h7 or a be quiet! Pure Rock for the hyper 212 evo price point and a thermalright macho if you can spend somewhere around 40-50 bucks
http://www.newegg.com/Product/Product.aspx?Item=9SIA4UF2DZ6565&cm_re=cryorig_h7-_-9SIA4UF2DZ6565-_-Product
http://www.newegg.com/Product/Product.aspx?Item=9SIA68V2326642&cm_re=be_quiet-_-9SIA68V2326642-_-Product
http://www.amazon.com/ThermalRight-Macho-size-reduced-HR-02/dp/B008SAOCHG/ref=sr_1_2?ie=UTF8&qid=1438706445&sr=8-2&keywords=thermalright+macho
http://www.amazon.com/Thermalright-814256001052-Macho-Rev-B/dp/B00PKJ21LW/ref=sr_1_1?ie=UTF8&qid=1438706445&sr=8-1&keywords=thermalright+macho
If your price point starts going higher, i recomend stepping up to dual rad AIO or a dual tower heatsink if you prefer to stay away from AIOs
http://www.amazon.com/Phanteks-Heat-pipes-Premium-Patented-PH-TC14PE_BK/dp/B007ZZE63A/ref=sr_1_2?ie=UTF8&qid=1438706611&sr=8-2&keywords=phanteks
http://www.amazon.com/Noctua-NH-D14-Heatpipe-Bearing-Cooler/dp/B002VKVZ1A/ref=sr_1_2?ie=UTF8&qid=1438706632&sr=8-2&keywords=nh-d15
http://www.newegg.com/Product/Product.aspx?Item=9SIA4UF1H68938&cm_re=cryorig_r1-_-9SIA4UF1H68938-_-Product
http://www.newegg.com/Product/Product.aspx?Item=9SIA2W02RF7554&cm_re=enermax_cpu_cooler-_-35-214-061-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103201&cm_re=RL-N24M-24PK-R1-_-35-103-201-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103181
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181060&cm_re=h105-_-35-181-060-_-Product
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/423063-h440-cooling-options/#findComment-5681174
