Didn't know where to put this thread so Ima throw it over here.
Just a question about cleaning the dust out of computers, is it a bad idea to use air compressors, because my friend said they spew moisture and could ruin your hardware. Is it best sticking with air in a can?
My Little Gaming Rig:
CPU: FX 8320 | MOBO: Gigabyte 970A-D3P | RAM: G.Skill Ares 2x4GB | GPU: Sapphire Dual-X R9 270X | Storage: Seagate SSHD 1TB | Case: Corsair 200R | PSU: CM 550W V-Series
Upgrades to come: CPU FAN: Corsair H100i | RAM: 2 more 4GB sticks | GPU: Another R9 270X running in crossfire | Storage: Samsung 120GB SSD | PSU: Corsair 800w
https://linustechtips.com/topic/422044-cleaning-pc-question/
No, you can go crazy with them and it's fine, just hold fans down. Air in a can is has more probability of spraying liquid out than an air compressor.
If the compressor is lubricated by oil, there is a fair chance that it will be spewing a bit of oil.
My PC CPU: 2600K@4.5GHz 1.3v Cooler: Noctua NH-U12P SE2 MB: ASUS Maximus IV RAM: Kingston 1600MHz 8GB & Corsair 1600MHz 16GB GPU: 780Ti Storage: Samsung 850 Evo 500GB SSD, Samsung 830 256GB SSD, Kingston 128GB SSD, WD Black 1TB,WD Green 1TB. PSU: Corsair AX850 Case: CM HAF X. Optical drive: LG Bluray burner  MacBook Pro, Hackintosh
https://linustechtips.com/topic/422044-cleaning-pc-question/#findComment-5668094
The issue with air compressors is the high output pressure. You have the probability of damaging electrical components (i.e. high pressure air blowing capacitors off), and damaging fans. That said, if you adjust the compressor, and reduce the output pressure to a reasonable level, you should be perfectly fine -- you don't need 30+ PSI to blow out dust. It's not like you're trying to kill a dust demon...or go Ghost Busters mode on your PC.
As @AlwaysFSX mentioned, just hold the fans and prevent them from rotating if you are cleaning them off.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/422044-cleaning-pc-question/#findComment-5668099
holding fans so they don't move will ensure they won't go to the graveyard am I right?
https://linustechtips.com/topic/422044-cleaning-pc-question/#findComment-5668188
air cans can spray liquid so I wouldnt use those. apart from that compressed air or a vacuum cleaner are fine just make sure to
1. hold the fans so they dont counter- or overspin or create an electrical current flowing back to the board
2. take your distance so you dont create too much pressure on the components since they can be blown off by that and most importantly the air would create friction which also causes an electrical current flowing through your components.
Bitfenix Phenom M White | ASUS RoG Maximus VIII Gene | Intel i7 6700K @4.6GHz | HyperX Savage 2800MHz CL14 DDR4 16GB | EVGA GTX1080 SC | Intel 750 Series PCIe SSD 400GB | EVGA SuperNova G2 550W | Windows 10 Professional x64 | Logitech G900, Corsair K70 RGB MXbrown O-ringed, BeyerDynamic DT880 (600 Ω) on Fiio E10K & Samson Meteor | Dell U2715H 27", Samsung SyncMaster P2450H 24", Samsung SyncMaster 931BF 19" | DIY Ambilight
https://linustechtips.com/topic/422044-cleaning-pc-question/#findComment-5668189
