http://www.pccasegear.com/index.php?main_page=product_info&products_id=32785
I was looking at this SLI brisge and noticed it said "High pixel clock design for 4K and 120Hz gaming."
Is this true? I doubt it
PC is Intel Core i5 6400, GIgabyte H170 Gaming 3, Corsair Vengeance LPX 2x4GB 2400Mhz ,Sandisk Ultra Plus 128GB, WD Blue 1TB, NZXT S340, ASUS Geforce GTX 960. Fractal Design Tesla R2 650W. http://au.pcpartpicker.com/p/793XNG. Graphics card choices don't always have to be dictated on performance. If you want the game stream and power consumption of the GTX 970 get that. If you want raw performance of the R9 390 get that. In the end we are all gamers, so what if your buddy gets an extra 5 fps?
https://linustechtips.com/topic/419821-does-evga-sli-bridge-make-a-difference/
ROG for swag but
it just a piece of PCB
no fancy booster inside
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
