So i have been trying to build my first PC and have a limited budget due to my age. The problem i have is with the PSU
My parts all work together as far as i can tell, but i am trying to use the Corsair Builder Non-modular 430w PSU
The problem i face is whether or not the PSU can support enough power to my system, and whether or not i will have enough Cable for all of my components.
The parts list is here, and i really need help: https://uk.pcpartpicker.com/user/dis_the_chris1/saved/QFWCmG
Any other advice you could give on the system would also really help out (also, please ignore the keyboard, it is only there so when i buy it, its in the same list as everything else)
Thanks,
Chris.
EDIT: i had swapped the previous drive with a Cooler Master Thunder 600W supply
the new PSU can be found here. Any thoughts?
https://uk.pcpartpicker.com/part/cooler-master-power-supply-rs600acabd3
Quack (if you can read this, stop highlighting you perv)
Building a system with an i5 4690K 3.5GHz, 16GB Corsair Vengeance RAM, Asus Z97-E, Asus 4GB Geforce GTX 960 Strix, Cooler Master Hyper 212 EVO, Sandisk SSD Plus 240GB, Seagate Barracuda 3TB, XFX ProSeries 450W PSU and a Corsair 200R Mid-Tower Case. PM me if you feel lonely, because i am too.
https://linustechtips.com/topic/419438-help-me-please/
Thanks,
Chris.
you are fine however you cant really do any heavy ocing
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/419438-help-me-please/#findComment-5637308
Some of the higher wattage PSU's are actually cheaper.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/419438-help-me-please/#findComment-5637310
960 isnt gud enough for 4gb
buy a r9 380
Sorry, could you give me more reasons and information? i have heard great things about the 960 and 4GB is all i need.
https://linustechtips.com/topic/419438-help-me-please/#findComment-5637319
Power supply is a no-no. Corsair makes excellent power supplies (well, the ones that are manufactured by SuperFlower and SeaSonic), but the CX series is definitley not one of them. If you're going for a Corsair power supply, use a TX, RMi, HXi, or AXi.
None of Corsair's stuff is made by Super Flower dawg. Older designs used Seasonic. They have the AXis which are great (bar coil whine) and are made by Flextronics. The RMis are made by CWT and are great as well, same goes for the HXis. They're all just overrpriced :P
https://linustechtips.com/topic/419438-help-me-please/#findComment-5637338
https://linustechtips.com/topic/419438-help-me-please/#findComment-5637376
My bad. I could have sworn they were made by SuperFlower, my mistake. I have an HXi and an AXi power supply by Corsair, and I have to say that I love them. I had heard about coil whine on the AXi line, and I was initially concerned by that. But, they've proven to be amazing power supplies, and I'm glad I went with them.
As long as yours have no coil whine then don't worry about them. Nonetheless buy other things. Better for your wallet that way :P
https://linustechtips.com/topic/419438-help-me-please/#findComment-5637404
http://www.coolermaster.com/powersupply/thunder/thunder-600w/
I switched it to this. Is this a better buy? i am on a budget that doesnt have much breathing room, and this seems quite good
any thoughts?
https://linustechtips.com/topic/419438-help-me-please/#findComment-5637650
Muuuuuuuuuuuuuuuch better. This power supply is safe and reliable.
Great, thanks very much for your help. I am now much more confident in this build. Thank you!  :)
https://linustechtips.com/topic/419438-help-me-please/#findComment-5637702
