I finished building my computer and while playing games the gpu's temperatures under load is at 70. I have a gtx 970 with a reference cooler and it has been in the 90's outside (I have a room fan to cool me in this heat. Are these temps ok? and i need to work on my cooling or is it going to improve as the weather improves?
https://linustechtips.com/topic/419224-graphics-card-temps/
https://linustechtips.com/topic/419224-graphics-card-temps/#findComment-5634630
Those temps are fine. Not a big deal at all.
https://linustechtips.com/topic/419224-graphics-card-temps/#findComment-5634667
I think the max temp for the 970 is about 100-110C. Graphics card of that caliber are meant to run at high temperatures. If you still feel uncomfortable with it, or you are getting artifacts or any other abnormalities with the video, which seems unlikely to happen, try setting a more aggressive fan curve.
https://linustechtips.com/topic/419224-graphics-card-temps/#findComment-5634724
Those temps are fine because you have a reference cooler. My g1 runs at about 66-67 under load and it's about the same temp here +/- 5 degrees
The Brokish Boy v1: CPU: i7-8700k GPU: MSI Gaming X GTX ti MOBO: Asus ROG Maximus X Code Ram: G.Skill Trident Z 4x8gb 3200mhz DRIVES: 2x3TB WD Black , 500gb Samsung 850 EVO SSD, 500gb 970 EVO SSD Case: be quiet! Dark Base Pro 900 Black Headphone: ATH-MSR7 Mic: Blue Yeti Monitors: 27" BenQ GW2765 1440p; IPS, 27" Acer Predator XB271HU 1440p; VA
https://linustechtips.com/topic/419224-graphics-card-temps/#findComment-5634729
70° under load is top.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/419224-graphics-card-temps/#findComment-5634759
my reference 980ti sits at about 83c under load. I'd consider your 70c rather frosty
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
https://linustechtips.com/topic/419224-graphics-card-temps/#findComment-5634824
