Need help for new headphone
cjtaxi
hi guys...i was gonna change my headphone again...i was looking at the Sony MDR-1A or the Beyerdynamic Custom One Pro...so i was planning to use this headphone as my daily driver...my main usage is for gaming and listening to music (EDM, Pop) so which one do you guys suggest...which is better for my case? thx b4
N.B : sorry for bad english :D
edit : budget is at US$300 max
Hyper X Cloud. I'm just guessing the budget, next time add a budget.
|Intel Core i5-4670K| |Gigabyte Z97P-D3| |Seagate 1TB SSHD| |Fractal Design Define S| |Corsair CS650M| |Asus PB278Q| |Cooler Master CM Storm Devastator Bundle|
Either that you mentioned would work well with those genres. The Custom One Pro will achieve more bass, especially with the adjustable bass port.
No.
No.
Yes.
Yes.
Comparing that headSET to the headPHONES in the OP is dumb. End of discussion.
You must be fun at parties  :D
ah yes sorry...budget is US$300 max...
No.
ah ok thx
or is it any other suggestion in my price range for my usage?ty
At least I get invited.
Yup, whatever.
ah ok thx
At that budget I'd suggest fidelio x2 or he400 as well.
For a daily driver, it may need to be closed, but idk. If it can leak sound, those two are pretty great, but the he400 will also need an amp for it to really be driven.
guys...but overall the beyerdynamic custom one pro is good enough or is it only so-so?
For edm and PPP I think the v moda m100 is an easy winner for closed back headphones.
For open the x2 is Also very good
hmmm guys what about beyerdynamic DT990 ? many reviews find it good / excellent
