I wanna do some testing on my iGPU but it's nearly impossible to force most applications to render on it because it seems my GTX 970 as the first GPU so it automatically uses that instead. i know if I remove my GPU it will automatically use the iGPU but I'd rather not have to do that everytime I wanna switch graphics adapters.
If i disable my dedicated GPU in device manager will it force the system to ignore it completely r shoudl i just remove it?
https://linustechtips.com/topic/417877-will-disabling-gpu-device-act-as-removing-it/
I'd just take the GPU out of your system. Not this.
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
remove it.
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
