How does this build sound :p
Solved by arronleeds,
I was wondering if there is something that im missing with this build.
Its going to be called project gamecube becouse ill be painting my case in the collours of the original gamecube and ill be putting a gamecube logo on the front.
What ill be upgraiding: Ram to 16gb, boot ssd, aio cpu watercooler and a BIG MAYBE, a second gpu
Link to build: http://pcpartpicker.com/user/thauolar/saved/9JBtt6
bro if you do that to the case that will be epic, i wanna graffiti my case but im no artist
, it would look like someones just thrown random paint on it.
