Can anyone recommend me a computer case. I been looking everywhere and I can't find anything that fits what I want for the past 4 weeks. (I'm going for a nvidia theme)
Requirements:
Must be a Black case
Must come with a front panel door
Must come with at least 2 5.25 in drives (or just one if it has a built in fan controller)
Must have 2 USB ports on it and one has to be 3.0 (both can be 3.0 though)
Must have a BIG sidepanel window (and the window can't have a spot for a fan)
Must have support for a 240mm radiator
Needs to at least support 12.5 inch GPUs
Must at least be a ATX Mid-tower, will take a full tower if it meets everything else
Two cases that I found that might meet these requirements, but I wanted to know if you know anything about them?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156304 (was going to get this one, but has a big blue power led that goes across the top, if anyone knows how to make it green, I would more then likely buy it.)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811353076
https://linustechtips.com/topic/415573-pc-case-help/
If you're willing to have a max GPU length of 12.2 in, get the fractal design define R5. To be frank, 12.5 in is ridiculously long (no dick joke intended), and I doubt you'll find a card that long
http://www.fractal-design.com/home/product/cases/define-series/define-r5-black
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/415573-pc-case-help/#findComment-5590194
Fractal Design Define R4/R5
                        Arc Midi R2
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/415573-pc-case-help/#findComment-5590224
You're looking at cases that are decidedly low end, did you have a budget in mind?
Under $150 would be nice
The original card I wanted was the Zotac GTX 980 TI AMP Extreme Edition, but I am willing to go with a 980 ti G1 Gaming if need be.
Phantom 530, be all and end all.
I actually own that case xD. Currently selling because of the size was unable to do a lot of upgrades to it, because of how far I have to carry it, and it is super easy for me to carry a mid tower (I would however get the version with the green leds in it, only if I don't have a choice)
http://www.corsair.com/en-us/obsidian-series-750d-full-tower-atx-case
that'll be 179.99, you have yourself a wonderful day
That is kind of out of my budget, also doesn't look like it has a front panel ,unless those open instead of taking them off?
https://linustechtips.com/topic/415573-pc-case-help/#findComment-5590285
D:
https://linustechtips.com/topic/415573-pc-case-help/#findComment-5590367
