What have you tried and what did you get?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/412409-gpu-for-ultra-wide/#findComment-5550129
yea, because its totally worth to get a 15% faster card that cant be paired with the current one......
The way OP worded himself is he just got the 970 and does not enjoy it, he most likely can still return it and get his money back.
https://linustechtips.com/topic/412409-gpu-for-ultra-wide/#findComment-5550242
You're correct
I am returning the 970 and thinking about the 980ti since it's only $250 more.
Thoughts ?
Rather not do sli or crossfire since I've heard bad stories about it.
https://linustechtips.com/topic/412409-gpu-for-ultra-wide/#findComment-5550355
It's only a 1080p display, a 970 should be more than OK. What CPU do you have?
You're correct
Thoughts ?
Those bad stories come from people who had a look at it a decade ago and haven't tried it again since.
https://linustechtips.com/topic/412409-gpu-for-ultra-wide/#findComment-5550370
I5 4690k
I was struggling with with the evga 970 to stay above 30-40 on certain games
https://linustechtips.com/topic/412409-gpu-for-ultra-wide/#findComment-5550429
I have the lg 34UM64-P 2560 x1080
Vertical Refresh Rate 50 - 75 Hz
Horizontal Refresh Rate 30 - 90 kHz
What video card do you suggest
Tried the 970 but I wasn't getting the performance I was expecting
Might of been a bad card.
Thanks in advance !
390X should be your best answer.
as a rule of thumb. AMD generally does better at higher resolutions. So if you are running 1440p or higher (like 3440x1440 or 4k) then AMD usually have the better solution FPS, AND price wise.
EDIT:
2580x1080p - AMD R9 390 or AMD R9 390X will be your best bet. Overclock a 390, or a stock 390X, ofc you can also overclock the 390X for even better performance
Brands to shop by when getting AMD:
Best performance and cooling: Sapphire and MSI
Best "middleground": Powercolor, Gigabyte, Club3D
Best customer service: XFX
Wildcard: Asus (never trust their coolers)
https://linustechtips.com/topic/412409-gpu-for-ultra-wide/#findComment-5550825
EDIT:
r9 390 performs exactly the same as a slightly oc'd 970
https://linustechtips.com/topic/412409-gpu-for-ultra-wide/#findComment-5551008
EDIT:
I agree with you in regards to the 390x being the best bet.
"as a rule of thumb. AMD generally does better at higher resolutions. So if you are running 1440p or higher (like 3440x1440 or 4k) then AMD usually have the better solution FPS, AND price wise."
Crossfire vs SLI, yes, I also agree towards AMD.  But to say this for a single card solution and as a blanket statement is STUPID.  Plain and simple.  Reading a lot of comments coming from you leads me to believe you are fanboying it up.  Fury X vs 980 Ti @ 4k  Clearly shows that is very close but 980 Ti still leads on average.  Some games lead towards Fury X. (FC4 and Shadow of Mordor)  Again this can be subjective because different people will get different cards and overclock differently.
http://www.maximumpc.com/gtx-980-ti-vs-fury-x-overclocking-showdown/#page-2
At this point I could care less anymore if I was being rude.
You may think I am leaning towards NVIDIA?  I could give a shit.  I buy whatever is faster.  But to say ""as a rule of thumb. AMD generally does better at higher resolutions. So if you are running 1440p or higher (like 3440x1440 or 4k) then AMD usually have the better solution FPS, AND price wise" is complete ignorance and toxic. You also said "usually" (taken with a grain of salt) so it could be interpreted as in general, AMD is better for higher resolutions.
OT:  I used to have a 2560x1080 monitor.  You would do quite well with a 390 or 390X.  I do not recommend the 980 or even 970.
I have a potato!
https://linustechtips.com/topic/412409-gpu-for-ultra-wide/#findComment-5551025
