High temps?
Go to solution Solved by tomas710,
stable at 88 celcius and dipping to 87 at some times
On NCIX tech tips they got a max of 75ºC on a MSI 290X (Almost the same) and the GPU should be fine at 90ºC according to AMD, but it shouldn't be that hot on a good aftermarket cooler, so i would think something is not ok
Hi !
i was gaming with my MSI twin frozr r9 290 the other day and noticed that my card was loud as heck (while gaming) so i checked out the hw moniter and saw a 92 celcius on my card.
it wasn't a very hot day about 23 celcius and my cpu was just doing fine so i was playing reign of kings alpha 16 on my lg 29um67 and it was on full load, i don't know if it was throttling.
now when i watch the temps on idle after playing a game a day long its about 50 celcius so is this normal since i never experienced my gpu fan ramping up to 100 % before.
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/412205-high-temps/
* insert AMD heat joke here*
anyway, it shouldn't get this hot. maybe check/replace the thermal paste?
https://linustechtips.com/topic/412205-high-temps/#findComment-5547478
Hi !
The first thing I would do is to clean my PC. You should do that on a regular basis.
Also I would have a look at the thermal paste on your GPU. Cheap thermal paste can dry out after a while and lead to high temperatures.
But before you take your GPU apart get some new thermal paste, cause otherwise you will not be able to get it back together.
https://linustechtips.com/topic/412205-high-temps/#findComment-5547504
AND thermal pads, if they are broken he won't be able to resuse them.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/412205-high-temps/#findComment-5547512
even if the card is 6 months old ?
https://linustechtips.com/topic/412205-high-temps/#findComment-5547552
Hi !
That is hot for a Twin Frozr, even if the 290 can handle those temps. I would clean the card outside the PC, remember to hold the fans if you are using canned air or similar. The next step id that doesn't help is changing the thermal paste, the TIM itself is not a big deal, anything decent (AS5 or better) will do, the issue id the thermal pads, if you're lucky you can reuse them but sometimes they get torn, if that happens you should have thermal pads but i'm not sure the thickness that would be apropiate, i think 1mm is the standard but it is an aftermarket cooler so, i would consult some reliable source over what thermal pads to use
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/412205-high-temps/#findComment-5547557
whats a normal temp for a msi r9 290?
https://linustechtips.com/topic/412205-high-temps/#findComment-5547563
whats a normal temp for a msi r9 290? idle and load?
https://linustechtips.com/topic/412205-high-temps/#findComment-5547572
i cleaned my pc a week ago~ and also i just tested it with furmark here are the results i tested it over a 5 minute period 60ac8b5c3fa0a826eeb67d27af4a3360.png
http://gyazo.com/60ac8b5c3fa0a826eeb67d27af4a3360
https://linustechtips.com/topic/412205-high-temps/#findComment-5547585
Well, i assumed it was older, and yeah, if it's only 6 months old is unlikely that the pads will break but it's always possible, so be very gentle when detaching the cooler. What thermal paste are you using?
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/412205-high-temps/#findComment-5547601
https://linustechtips.com/topic/412205-high-temps/#findComment-5547602
Don't use Furmark!, just learned yesterday from someone else in the forum that it has burned many GPUs
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/412205-high-temps/#findComment-5547612
by cleaning i mean removing the dust with air all the fans are clean and the gpu pretty clean also
https://linustechtips.com/topic/412205-high-temps/#findComment-5547615
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/412205-high-temps/#findComment-5547647
You tested temps after cleaning the card? also, any overclocking, if so, how much?
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/412205-high-temps/#findComment-5547663
That's a great temperature, under 90 is totally fine with that card. Now I advise you to uninstall furmark since it is REALLY bad for your GPU.
Mah Build:  CPU: Intel i7-7700K COOLING: NZXT Kraken X52 GPU: Asus Strix GTX 1080 MOBO: Asus Strix Z270F RAM: 16GB GSKILL TridentZ RGB 3000
CASE: In Win 303 STORAGE: Samsung 850 EVO 250GB, Seagate 1TB  SSHD PSU: EVGA Supernova G2 750W
https://linustechtips.com/topic/412205-high-temps/#findComment-5547684
my card memory is at stock and core is 3% overclocked with a 5% energy limit increase via the amd driver
https://linustechtips.com/topic/412205-high-temps/#findComment-5547699
also tested reign of kings and got 88 celcius with the same dips as furmark
https://linustechtips.com/topic/412205-high-temps/#findComment-5547709
Guess it was dirty, simple as that, i would play the same game that made it go over 90 and check temps to be sure
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/412205-high-temps/#findComment-5547746
while were at it is 28 celcius good for a fx 8350 at 4.1 ghz ? (the max was at load )
https://linustechtips.com/topic/412205-high-temps/#findComment-5547754
i think give or take my card runs a little bit hotter but the ncix crew probable ran it in a open air test bench so that benefits them.
https://linustechtips.com/topic/412205-high-temps/#findComment-5547770
https://linustechtips.com/topic/412205-high-temps/#findComment-5547774
I believe the 'official' max is 61ºC, but the thermal probe is not very accurate in FX chips, what cooler are you using?
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/412205-high-temps/#findComment-5547833
I think it's fine as long you dont keep the CPU at load all the time, wouldn't hurt to add a second fan to your cooler
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/412205-high-temps/#findComment-5547888
hyper 412s
https://linustechtips.com/topic/412205-high-temps/#findComment-5547897
