hello i am starting to sleeve a 8 to 2 6pin and 2 2pins but i am having some issues removing the wires. Every time i deal with wires that have to in one i always pull the wires out leaving the pin inside i have tried to remove them however it breaks the pin in the process so i am wondering if there is anyway i can remove them without damaging the pins.
it is likely that i am just going to have to get a crimping tool and some extra pins but i would like to avoid that.
LG 34" 21:9 1440p
1080ti EVGA FTW3
i7 8700k @ 5GHz 1.3V Delidded
https://linustechtips.com/topic/411678-double-wire-sleeving-issue/
are you using proper tools? a pin remover?
yes i bought a little pin removal tool
this one to be exact http://www.icemodz.com/store/#!/Great-ATX-EPS-PCI-E-Removal-Tool/p/23645274/category=5572975
You need to make sure the prongs on the tool are slightly bent inwards to properly compress the tabs that lock the pin into place:
