PSU above carpet - Solution
Solved by Guest,
Go buy a piece of plywood and cut it just big enough to fit under your tower. Cheap and easy.
Having your PSU fan side in is a no-no. Your fan intakes hot air from the GPUs doing that and when the GPU fans come on they'll be fighting eachother for air. Just get a plank of plywood or something and put it underneath the PC.
You don't want to suffocate your PSU airflow so I would move it to a desk or put something flat under the PC that it can rest on for cleareance
I have a plank of wood under my case, as the case holder i used to own before couldn't fit my 750D.
Thanks
