i7 4770 Overheating, Help!
Solved by Samdb,
Haswell is notorious for having a cheap TIM between the die and the IHS. This causes most CPU's to heat more than previous generations of processors, and it seems you have one of these CPU's. Unfortunately you cannot get an RMA on your CPU, however buying an aftermarket cooler such as the CoolerMaster Hyper 212 Evo would be a great addition and really help in lowering your temperatures.
Sam,
Intel Response Squad member
Share
Followers
2
