Okay, so I basically have my whole build planned out right now, the colour of each component included in the plan to suit my theme. I have chosen Corsairs Vengeance low profile RAM however I want it in white and the white edition only comes in 1.35v as opposed to their standard 1.5v sticks.
Now my question is, what are the advantages and/or disadvantages of me getting the 1.35v models? basically what difference will it make at the end of the day compared to 1.5v models; because I cannot for the life of me find out what it affects
Thanks in advance.
https://linustechtips.com/topic/40527-135v-low-voltage-ram/
Takes less power.
More overclocking headroom.
Less heat.
Good marketing point.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/40527-135v-low-voltage-ram/#findComment-524663
Awesome, thanks guys.
On that note though, its slightly beneficial so why do they not just make all models 1.35v?
That would decrease yields.  Not all RAM chips are capable of 1.35V.  So the standard is 1.5V, they have less throwaways.
https://linustechtips.com/topic/40527-135v-low-voltage-ram/#findComment-525413
It just sucks up less power thats all.
not really. ram doesnt take up a significant load of power.  It allows for more overclocking headroom as you can raise the voltage safely to 1.5. if you had a 1.5v 1333 kit you would most likely end up with a 1600 kit at 1.65v once you oc'd it, but a 1.35 kit can oc safely while still staying at a lower voltage.  So a better overclocker.
https://linustechtips.com/topic/40527-135v-low-voltage-ram/#findComment-525677
