I bought a 780ti pre-overclocked and the actual overclock is shocking.
GTX 780 TI GPU ENGINE SPECS: CUDA Cores 2880 Base Clock (MHz) 875 Boost Clock (MHz) 928 Texture Fill Rate (billion/sec)
That's stock
This is the overclocked one I bought.
What do you think a overclocked 780ti would be able to get up to -
With voltage:
Without Voltage change:
https://linustechtips.com/topic/404913-max-overclock-for-a-780ti/
All depends on the silicon lottery. What you pointed out doesn't help much/at all.
Try it out and see.
My friend got his 780ti up to 1200 something. (on a water block)
Project Cobalt:
CPU: AMD FX 8370 Motherboard:
Asus M5A97 R2.0
RAM: G.Skill Ares 16GB (2x8GB) DDR3 2133 GPU:
Gigabyte GTX 970 G1 Gaming Case: NZXT H440 (Blue)
Storage: Samsung 840 EVO 256GB +  2x 1TB WD Cavier Blue
PSU: Corsair 750G2
CPU Cooler: Swiftech H220X
Keyboard: Model M + a lot of others
Mouse: Logitech G502
Vintage Gaming PC: AMD Athlon T-Bird 800Mhz, Gainward nVidia Ti200 128MB, 512MB Crucial RAM DDR, Compaq ASPEN 2 OEM Board, Soundblaster Live! 5.1, Windows 98SE
Stable OC under my condition here in India,depends on the room temp you have there
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
Try it out and see.
What would you recommend I go to without waterblock and without changing the voltage?
Edit: Like a starting number to work from there.
Silicon lottery and if it's a good card(like KPE or Matrix), it can go up to 1500MHz. Even 1600-1700MHz in some extreme situations. But usually 1300MHz is the most you will be able to get.
INTEL Core i7-4790K  ASUS Maximus VII Ranger  CORSAIR Vengeance Pro 8GB 2133MHz  EVGA GeForce GTX 980 Ti  SAMSUNG 850 EVO 250GB  CORSAIR AX860i  CORSAIR Obsidian 750D
Mate can I have your setup? Like seriously! xD
Why do you have a higher Pixel and Texture fillrate than mine, that's down to the chip set isn't it?
idk, but its +/- 1, s negligible, what's your ASIC level ? higher the ASIC level, better the overclocking
PCPartPicker
So mine is pretty good at overclocking? And I will be able to get more performance?
yes
PCPartPicker
