According to the reviews on Newegg, you can change the color. However a common complaint is that every time you reboot or power down and come back on, it defaults back to the default color and you have to reset it to whatever your preference is.
Gaming Rig: Asus Z87 Pro, i5-4670k, EVGA Supernova 1000 P2, Corsair Carbide Air 540, NZXT Kraken X60, G.SKILL Ripjaws X (4 x 8GB @ 2133), 2 x EVGA GTX 980 SC, Samsung 850 Evo 500GB, Samsung 840 Pro 256GB, 2 x HGST Deskstar NAS 4TB 7200rpm
Plex Server/Couch Gamer: Gigabyte Z97MX Gaming 5, i7 4790k, Corsair HX750, Fractal Node 804, Deepcool Captain 240 AIO, G.SKILL Sniper Series (4 x 8GB @ 1866), MSI Lightning 780, Samsung 850 Evo 500GB, HGST Deskstar NAS 4TB 7200rpm.
Hello, I was wondering if I could change the Windforce led color on the gtx 980 throught the OC Guru II. I know you can do it with the 980 ti G1 edition but can I do it with the 980?
No, there only blue LED's on the 960/970/980 you can mod it to the color you like but you cant change it with OC Guru II.
CPU: Ryzen 7 5800x3D | MoBo: MSI MAG B550 Tomahawk | RAM: G.Skill F4-3600C15D-16GTZ @3800CL16 | GPU: RTX 2080Ti | PSU: Corsair HX1200 |
Case: Lian Li 011D XL | Storage: Samsung 970 EVO M.2 NVMe 500GB, Crucial MX500 500GB | Soundcard: Soundblaster ZXR | Mouse: Razer Viper Mini | Keyboard: Razer Huntsman TE Monitor: DELL AW2521H @360Hz |
edit: my mistake, the 970 and 980 did only come in blue.
The 960 and 980 ti can be changed because they have newer cooler designs that came with the "silent" and "stop" buttons on the card that also light up
Ok thanks DarkSmith2, can you recommend the best/ coolest gtx 980 for a black/red theme.
get a g1. Its the best performance wise.  Otherwise go with a msi gaming 980, but there will be no backplate.  I prefer the sleeker look of the black backplate on the g1.
MOBO- MSI z97 gaming 5  CPU- I5 4690k   GPU- G1 Gaming gtx970  RAM- 16gb Corsair Vegeance  PSU- Corsair RM650  COOLING- Corsair H110iGT
STORAGE- AMD r7 120gb SSD / 500gb HDD  CASE- Phanteks Enthoo Luxe   Sound-  Logitech z506 / Corsair Void  Peripherals- G710, G502
You could get the G1 and hardmod it yourself (change the LEDs) but you have to do a soldering job. But if i would be you, i would just buy a GTX980Ti  G1 instead.
